Front end question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2018, 06:13 PM
Front end question
Hi,
My 34 Plymouth sedan streetrod has a Mustang 2 front end. (I do not know what year Mustang it came from) To give you an idea of the weight. The engine is a Chevy 400 with aluminum heads backed by a 700r4 and 9 inch Ford diff. Manifold is Stealth. The body has fiberglass fenders and grille shell. Radiator is aluminum .Guessing total weight around 3250...could be less. This car rides a bit too firm.
I need to raise the front end about 1 1/2 inches and soften the ride. What is the best way to do this?
Thanks in advance. Jim
Old 08-31-2018, 06:38 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
I would call Eaton Detroit Spring. At last count, they had 16 different springs for the MII system. Maybe they could provide you with a smaller diameter wire for a softer ride but longer total length spring to raise the front of the car.
EATON Detroit Spring - The leading manufacturer of leaf and coil springs for the street rod and restoration industries
The Following 3 Users Say Thank You to techinspector1 For This Useful Post:
40Rod$charged (08-31-2018), 454 Rattler (09-01-2018), Bob37pont (09-01-2018)
Old 09-01-2018, 08:49 AM
454 Rattler's Avatar
NEVER SATISFIED !!
Please keep us updated on your results. Eaton springs is a good place to start.
454 RATTLER
Old 09-01-2018, 11:37 AM
454 RATTLER
Will do. Jim
front end alignment for 79 t-bird Heidts front sus jenajean Suspension - Brakes - Steering 4 09-16-2014 08:58 AM
1953 Buick Special-front end rear end?? mbjeep Suspension - Brakes - Steering 8 12-06-2009 06:32 PM
34 Ford chassis w/MII front end - front tires rub heyjude076 General Rodding Tech 4 04-09-2009 07:46 PM
front end tilt using my all steel front end old c10 head Body - Exterior 5 05-02-2003 01:45 PM
Tables of rear end and front end dimensions [email protected] Transmission - Rearend 1 08-21-2002 05:33 PM
