front end "wobble" - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 11-02-2015, 07:03 PM
31ROC's Avatar
Originally Posted by NEW INTERIORS View Post
play with the toe in and out...
LOL....toe has been "played with extensively"
  #62 (permalink)
Old 11-02-2015, 07:39 PM
Rip VW's Avatar
I will endevour to persevere
Last journal entry: This thread is officially Kaput as of 11/07/2017
Let me toss this out there, Have you checked the center plate that holds the front spring in the cross member? That needs to have the right amount of spacers so that it grips and holds the spring solid. I have seen loose front springs play havoc. Make sure the bolts are tight and no spring looseness there.
Does your uni-steer rack have any play at all? also I am thinking that a rack and pinion may be just too sensitive for the car.
Just tossing things out there.
  #63 (permalink)
Old 11-02-2015, 08:13 PM
NEW INTERIORS's Avatar
life is a temporary assignment
Fixed mine..
  #64 (permalink)
Old 11-03-2015, 06:39 AM
31ROC's Avatar
Fixed mine..
I "tried" playing with toe in/out at home, with a tape measure, string etc...never could get a could measurement since frame, oil pan, motor in the way...brought it to a shop where owner use to race modifieds, thru it up on the front end rack and adjusted it to his liking, made no difference.....wonder if I need to go to an extreme toe in or toe out?
  #65 (permalink)
Old 11-03-2015, 11:57 AM
How far did you go both ways ?? Forget about the motor being in your way.. Use a string and plumb bob to mark the floor, Then measurements can be taken...( do it off the center of tire front and back) Don't worry about going past 1/8 as always told by others, You have to find that sweet spot... This has been a problem for a long time... Mainly on t-buckets.. Without seeing your front end it's hard to say... But I think you can fix it with more toe...Most t-buckets like toe out...
  #66 (permalink)
Old 11-03-2015, 12:41 PM
31ROC's Avatar
String and plum-bob to mark the floor?
LOL, your gonna have to explain to this simple hot rod owner....not sure what that means!
  #67 (permalink)
Old 11-03-2015, 06:50 PM
Hope this help's..
If not let me know.. This is a great way to do it when the motor is in the way...
  #68 (permalink)
Old 11-04-2015, 06:35 AM
  #69 (permalink)
Old 11-04-2015, 06:41 AM
31ROC's Avatar
that's great! I'll try it this weekend hopefully....any suggestions on where to start initially?
1/8, 1/4" in or out?
  #70 (permalink)
Old 11-04-2015, 06:53 AM
31ROC's Avatar
I'm not sure what this "center plate" is.....am at work and will check this tonite....I am thinking the spring is U-bolted right to the axle? I just don't remember....
  #71 (permalink)
Old 11-04-2015, 06:57 AM
I would start with 1/8 in and move in from there, If that don't change anything, Start with 1/8 out and do the same. Move each time 1/8.. Hope this help's..
  #72 (permalink)
Old 11-04-2015, 08:14 AM
Rip VW's Avatar
I forget what the name of that plate is but it is what actually holds the spring in place. The U bolts go through the plate. If leaves have been removed from the spring pack the space must be filled with a spacer of some type to keep the spring pack tight against the cross member. Hope that helps explain what I meant.
  #73 (permalink)
Old 11-30-2015, 05:08 PM
31ROC's Avatar
Sorry this reply took so long, have not forgotten everyones help here....
I still plan to try the plum-bob thing for toe adjustment....and double check the tightness on the spring plate, just haven't had the time to work on this thing....if the weather holds out, Ill try these last measures ya'll have mentioned and report back.....
Front end alignment: When is "close enough", enough? scrot Suspension - Brakes - Steering 4 08-29-2009 05:40 PM
"soft" front end oldguy829 Suspension - Brakes - Steering 9 12-19-2007 02:43 PM
89 Durango front-end "bounce" Roddin Rob Suspension - Brakes - Steering 3 07-10-2005 04:22 PM
"Serious Suspension" bolt on front end jayjayjamez Suspension - Brakes - Steering 6 09-01-2004 10:29 AM
"T" Bucket front end reclusej Suspension - Brakes - Steering 2 02-27-2002 05:06 PM
