Front suspension control arm bushings 66 Chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2018, 03:22 PM
57halfton's Avatar
Has anyone here ever replaced the stock upper and lower A arm / control arm bushings on a 66 Chevy C-10 pickup ? How do they come apart and go back together ? Looks like they are threaded and screw together.
Old 09-13-2018, 07:55 PM
Old(s) Fart
Last wiki edit: Wheelbase database
That's exactly how they work. The bushings are threaded on the OD to fit the control arms and on the ID to fit the shaft. You have to screw them together simultaneously.
The Following User Says Thank You to joe_padavano For This Useful Post:
57halfton (09-13-2018)
Old 09-13-2018, 08:52 PM
57halfton's Avatar
Thank You,
Joe
Old 09-14-2018, 06:23 AM
Old(s) Fart
The one thing you need to be careful of is that the cross shaft needs to be centered fore-aft between the bushings before you tighten the bushings in the control arm. As the control arm moves up and down when you drive, the bushings "thread" the arm fore-aft on the shaft threads. You want to be sure it won't bottom, plus having the shaft offset one way or the other can make it impossible to set the caster alignment. I did this on a 1974 C30, which has the same arrangement. It just takes a little care.
Old 09-14-2018, 04:14 PM
57halfton's Avatar
Is there any torque specs on these ?
Old 09-14-2018, 04:25 PM
Old(s) Fart
Yeah, there's a torque spec of the bushing into the control arm. Unfortunately my service manuals don't go back that far.
Old 09-17-2018, 10:18 AM
PHWOARchild's Avatar
Take some pictures and measurements before you take them apart. I like to scribe a center line on the arm and shaft, also mark which way the shaft faces. I just did my Ford with a similar arm set up, 4 years ago. I don't recall if I torqued them. I just made them very tight. The arm on that has fine threads and the shaft had very coarse threads, it was easy to strip the arm threads, so be careful if your set up is like that.
71 skylark front passenger control arm bushings installation wiser626 Suspension - Brakes - Steering 3 11-22-2011 04:06 PM
Help with Front Control Arm Bushings TheBreeze Suspension - Brakes - Steering 11 11-06-2005 09:04 PM
poly lower control arm bushings dusterbd Suspension - Brakes - Steering 2 11-13-2002 03:19 PM
Control Arm Bushings [email protected] Suspension - Brakes - Steering 4 10-04-2002 07:26 AM
Lower control arm bushings. What are the tricks of the trade?? Jim Weeks Suspension - Brakes - Steering 7 05-11-2002 08:08 PM
