Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel fill neck safety valve?
Old 04-20-2017, 02:39 AM
staleg's Avatar
staleg staleg is offline
Last journal entry: Hand brake
Thanks for your inputs!
Since I accidently destroyed the hinge that attaches the neck to the Jaguar cap when I removed it, I decided to cut off the part that contains the safety valve, grind down the outer diameter a bit, and fasten it in the top of the filler pipe.
Works very well
