Fuel gauge problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2019, 12:26 PM
Fuel gauge problems
I have a sunpro fuel gauge and a bad sending unit checked it with a multimeter. My local speed shop said the ohm rating should be on the back of the fuel guage but it's not there. Does anyone know the ohm rating of a sunpro fuel guage or how to tell what my sending units ohm's are? I looked all over my sending unit and the only writing on it says made in China. So I'm not sure what my sending units ohm's are.
Thanks,
Rick
Old 03-23-2019, 02:41 PM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
Found a part number, guessing it will be 90 ohm
http://image.fourwheeler.com/f/82238...nding-unit.jpg
Old 03-24-2019, 08:26 PM
I found this sending unit and the image shows a chart showing empty/full resistance. So the sunpro gauge I have is aftermarket and on the chart it says most aftermarket gauges call for 240/33 ohms. Does anyone know for sure what the empty/full resistance should be on the fuel gauge sending unit with my aftermarket sunpro fuel gauge?
Thanks,
Rick
ID:	441659   Click image for larger version
Old 03-24-2019, 11:48 PM
Another chart: Universal Fuel Sender Questions and Troubleshooting
Old 03-27-2019, 11:53 AM
silver74vette's Avatar
Your best bet is to get a couple of resistors and put them in the circuit and see what it reads. I was not able to find anything for the sunpro.
You could also just buy a new gauge, then you would know for sure.
Old 03-27-2019, 12:14 PM
Thanks,
Rick
EZ to find this will tell you: https://www.tooldiscounter.com/ItemD...hoCMxgQAvD_BwE
Old 03-27-2019, 02:17 PM
Ok so I bought a new sending unit 33-240ohms and hooked it up. So now the fuel guage moves from empty to 3/4. It only goes to 3/4 full though. Before it would only go right to full and not move at all until i shut the car off. I think I might try and order the sending unit that JeffB28 just suggested. Thanks everyone I'll let you know how it goes. Also right now and when i tested the unit outside the tank I did not have the car running I just had it on auxiliary does that matter?
Thanks,
Rick
Old 03-27-2019, 02:22 PM
AllSteel34's Avatar
If you are unable to figure out the ohm rating on your gauge or sender, consider this possible solution:
https://www.speedwaymotors.com/Speed...ule,66534.html
Give the electronics two data points: full and empty. It figures out the rest.
I've used one. It works well. Installed in about an hour and it was much easier than changing senders.
Old 03-27-2019, 06:48 PM
rip-tide's Avatar
Thanks,
Rick
From Jegs:
"Sunpro Fuel Cell Sending Unit" ... Universal Fuel Level Sending Unit Kit; Ohms Empty: 240; Ohms Full: 33;
So looks correct, the gauge will work as it should off the tank as long as the ring is ground to the car. Make sure you have a full 12v on the wire to the sender. Make sure the arm of the float in free floating, not jammed up against the sending unit itself. At the full level, sometimes bending is required, not unusual.
Pep
Quadrajet running rich no matter what jet size is used modrummer Engine 30 10-06-2016 06:40 AM
65 impala 454 still overheating hotrodcommuter Engine 18 08-19-2016 08:39 AM
fuel gauge problems Bracewell Engine 1 10-26-2009 05:19 PM
fuel gauge problems grapro Electrical 5 03-16-2009 01:13 PM
Fuel gauge problems 1969NovaSS Electrical 5 05-04-2006 11:42 PM
