Fuel Pressure Regulator Thoughts - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 12-20-2018, 01:15 PM
55 Tony's Avatar
Originally Posted by S10xGN View Post
But wouldn't that depend on when you bought fuel? Don't remember when we used to start making winter blend at work, but it was much earlier than I expected. Been retired too many years to remember for sure, but seems like it shipped from Sept to April...
Russ
Yes winter gas comes long before winter and lasts into spring. It really boils when you get some winter gas and have an extra warm spring day. Been through that more than once. And the summer/winter mixes are different all over the country, mostly vary by county. Some warmer places never go to the cheap winter gas.
  #77 (permalink)
Old 12-20-2018, 04:19 PM
55 Tony's Avatar
Originally Posted by Greg T View Post
The Klotz additive makes the fuel more viscous which slows vaporization. Raises the boiling temp of gasoline. Helped a little. But at this stage of the game it's baby steps. Every little thing helps a little.
Can you kindly point me to were they claim it raises the boiling point of gasoline? I don't see that mentioned anywhere?
  #78 (permalink)
Old 12-20-2018, 10:12 PM
Greg T's Avatar
Music and Hot Rods
I spoke with a tech guy on the phone. Had some questions I needed answered before paying 50 bux a gallon.
  #79 (permalink)
Old 12-21-2018, 07:08 AM
55 Tony's Avatar
Hmm, I would have thought they would advertise something like that. Maybe he just told you what you wanted to hear or mayb
  #80 (permalink)
Old 12-21-2018, 08:31 AM
Greg T's Avatar
Music and Hot Rods
Maybe. It's irrelevant, tho, because I need 93 octane and the only 93 we have here has ethanol. The ethanol-free stuff is 91, so I need to use an additive anyway. AVgas is comprised of smaller molecules and is formulated to run at 3500+ RPM @ an ambient temp of 60. So driving around town she's fat. Klotz works extremely well regardless of whether or not it raises the boiling point.
  #81 (permalink)
Old 12-21-2018, 10:31 AM
I don't know much about gasoline tech except that they have winter blends and summer blends and they both are different on how they burn etc and I don't know why but I never had issues with boiling fuel in my truck before while running ethanol free gas but almost all the stations around my small town are now all using e10 so I can't escape it and have to use it. One of the few stations that had straight gas that I always went through back in 2017 I ran there gas all summer long with no boiling issues after shutoff.
Sometime in early 2018 they went to e10 and all the other stations have been e10 for some time and after having e10 in my tank I started to have the fuel boiling issue in the hot months and slightly loosing fuel pressure after some running time. And I like you have tried a few things to remedy the situation but have yet to have success but it got colder out by the time I had some more options it was to cold for it to happen anymore so I am waiting for next summer to try to do a few more things and see if it stops the stuff.
I just think today's fuel is just not really as compatible with carburetors like it once was since fuel injection has been the standard for 30 plus years now. I read that the current ethanol blends will start to boil just over 110 degrees.
Only thing different about my truck from 2017 to 2018 was a engine swap and putting in an electric holley inline fuel pump and nothing else.
  #82 (permalink)
Old 12-21-2018, 10:39 AM
Greg T's Avatar
Music and Hot Rods
Yeah, I'm waiting, too. I have this return style regulator to install, and I'm thinking of incorporating a small tranny cooler under the truck to run my returned fuel thru before it enters the cell. I am still toying with the idea of installing a couple of vents in the hood near the cowl. The vents should allow the air coming thru the radiator to vent out the hood and allow swifter air movement under the hood. Hopefully, the air being ingested will also be cooler. My physical condition does not allow me the option of removing and wrapping my headers, which I'm sure would nearly cure the issues. For now, it's piece by piece, little by little. I'm making progress.
  #83 (permalink)
55 Tony's Avatar
Yes that 110 boiling point is about right for "winter gas". Even that changes all across the country with different temperatures and different smog/pollution regulations. Evaporated gas pollutes a lot more than burnt gas so this is one situation where the fuel that is better for the environment is also better for carbureted engines.
  #84 (permalink)
Old 12-21-2018, 10:50 AM
I have no issues with fuel boiling after shutoff if its less then 60 degrees outside and it was only during the summer months of 70 plus degree days I had that issue and that was with summer blend fuel and I don't know when they switch to winter blend up here in Ohio but the last times of 70 degree weather was in August on average and once September rolled around and the temperatures dropped in the lower 60's and below I never had that issue anymore of the fuel boiling and under hood temperatures was not as hot.
I still though have my fuel pressure start off at 6 psi but after running a while it goes down to about 4 psi so don't know what that issue is yet but I am going to install a return line this coming spring so my pump is not dead head and just constantly pushing fuel nowhere till it needs used so I can keep a constant fuel flow and also my fuel is not there just collecting heat during the the hottest months. I also might buy a hood with a hood scoop on it so more heat can escape the engine bay as well.
Those are my few things I am going to try and see how it works.
Fuel pressure regulator not lowering pressure stanley9875 Engine 19 05-18-2017 01:26 AM
Oxygen regulator converted to air regulator deadbodyman Garage - Tools 15 04-28-2012 08:53 AM
"Quick fuel" fuel pressure regulator bigdog7373 Engine 9 11-15-2010 06:35 PM
V8 w/ carburetor + eletric fuel, runs too rich. Do I need a fuel pressure regulator? 5_speed Engine 17 10-25-2009 02:51 PM
Convert External Regulator To Internal Regulator 83F150 Electrical 1 05-18-2008 09:10 AM
