Fuel Return - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2014, 06:08 PM
Fuel Return
I now have a fuel cell in the bed of my truck feeding directly to the carb. The carb is a quadrajet on a 454 big block, My pump is a Mr. Gasket #105. I bypassed the regulator completely which I assume is causing my carb to over flow... My question is what will happen if I hook up the regulator while capping the return line(I want to avoid drilling a hole for a return line in my fuel cell)? Is this something I can get away with or am I a just going to have to bite it and drill a hole?
Old 03-19-2014, 06:14 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Most commercially-available fuel cells have at least two outlets, one of which could be used as a return. Dead-heading the fuel against a regulator will shorten pump life and heat the fuel.
The Following User Says Thank You to techinspector1 For This Useful Post:
CodyBob (03-19-2014)
Old 03-19-2014, 09:06 PM
4 Jaw Chuck's Avatar
...or run a low pressure electric Carter pump, no return needed.
— Han Solo
The Following 2 Users Say Thank You to 4 Jaw Chuck For This Useful Post:
CodyBob (03-19-2014), NEW INTERIORS (03-19-2014)
Old 03-19-2014, 09:11 PM
sqeezeit's Avatar
would the carter p4389 work for this?
Old 03-20-2014, 12:34 PM
bondo's Avatar
Ayuh,... That would be Correct,...
Old 03-20-2014, 12:41 PM
Yep, I like them...quiet compared to a Holley pump too. Need to verify if they flow enough for your application though, I've doubled them up and plumbed to both ends of a fuel log to get more flow rate to feed a Holley DP before. Ran a single to a Holley 650DP on my Mazda rotary for road racing, very reliable
Doubled up they give you fail safe for many applications such as marine where you may need it.
Cheap like Borscht!
— Han Solo
Old 03-20-2014, 12:56 PM
sqeezeit's Avatar
Cheap like Borscht!
I wonder what the difference is between the carter 4389 and 4070? Im thinking of using this or one of these also.They dont need return or reg as far as I know but wouldnt a return be better for it or not a big deal with this one?
Old 03-20-2014, 02:52 PM
ericnova72's Avatar
More for Less Racer
#4070 is automotive application, #4389 is marine application. Only difference is marine is coated for corrosion resistance(black powdercoat I believe). Summit's online pics don't show a difference due to generic photo.
CodyBob, your #105P pump and regulator are the same as Holley #12-802-1 "Blue" pump and regulator kit, which comes with the Holley #12-803 regulator. These regulators are a "deadhead" style, which means no return line. You have to use the regulator, pump puts out 9 PSI, way too much for the Q-jet float to handle. Just plug the unused port in the regulator and then adjust to 4-5 psi.
It takes a different regulator to run with a return line - Holley #12-803BP(BP for By-Pass)
carb, fuel cell, return line
What to do with fuel return? bonuts Engine 5 08-12-2013 08:11 AM
fuel return? Bauer1287 Engine 3 08-21-2011 06:00 PM
Holley fuel pump, return line or not to return line??? JD's camaro Engine 1 07-16-2010 05:17 PM
fuel return line Q nova 1 kenobi Engine 6 03-13-2005 05:25 PM
fuel return line 71 Red Sled Engine 3 03-18-2004 08:14 PM
