Hot Rod Forum : Hotrodders Bulletin Board (https://www.hotrodders.com/forum/)
-   Hotrodding Basics (https://www.hotrodders.com/forum/hotrodding-basics/)
-   -   FYI cooling a SBF (https://www.hotrodders.com/forum/fyi-cooling-sbf-487913.html)
tapkoote 08-27-2017 07:49 PM
FYI cooling a SBF
1 Attachment(s)
On very hot days 85+*, stop & go traffic, I'll get vacuum lock in the fuel supply. With the engine heat soaked and temp at 220*. I ran across a guy with a Sunbeam Tiger, they also have cooling problems, he had me look up this article. Cooling the Sunbeam Tigerby Tiger Tom and Chuck King - Tigers East/Alpines East
It may have been posted before but I haven't come across it. And after building a fan shroud, from junk yard pieces, it's worked for me.
I'm running a 17" 7 blade fan, Griffin 1 1/4 " rad. and dammed up all the holes around the shroud.
86* today - cross town traffic, just barely got over 180*. It would have been 200* at the second stop & go light. And 220 not long after.
keep kool
delawarebill 08-28-2017 08:43 AM
hot sbf's
i feel the shroud was the biggest key part. i went a little different in the mustang. 3 core alum rad, factory shroud, 19" flex fan. works for me.
FASTFORD 08-28-2017 12:43 PM
when I first got my coupe on the road there was a similar issue.
I got lucky & talked to an old hot rodder that had built many cars.
drill one 1/8 hole near the outer edge of the T-stat to allow air to purge when filling the system.
if the radiator is 18" wide, no fan smaller than 16" diameter &
17" is best. that is an example for any size radiator.
shroud on radiator with fan half in/half outside the shroud.
force all air flow through the radiator. block any air passage under,over or around the sides.
congratulations on getting your ride to run cool :thumbup:
tapkoote 08-29-2017 12:31 PM
[QUOTE=FASTFORD;4282249
[/QUOTE]
They did test that, myself, haven't ever had trouble filling a SBF even with stock manifold -knock on wood-
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
