FYI cooling a SBF - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2017, 06:49 PM
tapkoote's Avatar
Last journal entry: Gremlins make noise
FYI cooling a SBF
On very hot days 85+*, stop & go traffic, I'll get vacuum lock in the fuel supply. With the engine heat soaked and temp at 220*. I ran across a guy with a Sunbeam Tiger, they also have cooling problems, he had me look up this article. Cooling the Sunbeam Tigerby Tiger Tom and Chuck King - Tigers East/Alpines East
It may have been posted before but I haven't come across it. And after building a fan shroud, from junk yard pieces, it's worked for me.
I'm running a 17" 7 blade fan, Griffin 1 1/4 " rad. and dammed up all the holes around the shroud.
86* today - cross town traffic, just barely got over 180*. It would have been 200* at the second stop & go light. And 220 not long after.
keep kool
Old 08-28-2017, 07:43 AM
delawarebill's Avatar
hot sbf's
i feel the shroud was the biggest key part. i went a little different in the mustang. 3 core alum rad, factory shroud, 19" flex fan. works for me.
Old 08-28-2017, 11:43 AM
FASTFORD's Avatar
when I first got my coupe on the road there was a similar issue.
I got lucky & talked to an old hot rodder that had built many cars.
drill one 1/8 hole near the outer edge of the T-stat to allow air to purge when filling the system.
if the radiator is 18" wide, no fan smaller than 16" diameter &
17" is best. that is an example for any size radiator.
shroud on radiator with fan half in/half outside the shroud.
force all air flow through the radiator. block any air passage under,over or around the sides.
congratulations on getting your ride to run cool
Old 08-29-2017, 11:31 AM
tapkoote's Avatar
[QUOTE=FASTFORD;4282249
[/QUOTE]
They did test that, myself, haven't ever had trouble filling a SBF even with stock manifold -knock on wood-
fyi beertracker Off-Topic 55 10-09-2013 02:34 PM
FYI Intro... Bowtie Believer Introduce Yourself 1 10-24-2010 12:10 PM
Fyi To All!!!! Bonhorst Engine 3 01-23-2010 10:00 AM
Fyi rodit Introduce Yourself 3 12-17-2005 07:18 PM
fyi axle bastard Hotrodders' Lounge 3 05-20-2003 01:31 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
