Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - garage paint booth help please
  #41 (permalink)
Old 02-26-2009, 07:28 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Last wiki edit: Stripping paint
Wiki Edits: 11
booths
ill tellyou somethingyou really need to know,some of my best jobs were in homemade booths,i have a devilbis booth its main problem is not enough light on the bottom i cant see the clear very well so illdo the hood and set my speed then do sides by that speed i think it needs lites a foot off the ground and end to end ill try to get pics so you can see the light positions the EXPERTS designed,there are no lites on the cieling and it doesnt need them they are in the hips though.i guess what im tring to say is you can always make changes according to YOUR needs and you can adjust your technique to make up for the short commings youll run into but i can tell youll go far cause you do your research and want things right,so get er done and lets paint some cars itll be a good one youll see. ok lets see if i can screw up these pics again
Name:	100_5278 (Small).jpg
ID:	36560   Click image for larger version
Name:	100_2038 (Small).JPG
