gas tank fuel neck - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2012, 09:27 AM
gas tank fuel neck
Hi guys,
In my 33 ford, I have the gas tank installed behind the seat. It is a Tanks Inc universal steel unit. I have a remote fill up on the fender, & need to do some plumbing now. I need a 2 inch fuel neck to weld to the tank, & Tanks Inc has them, but they are only 2 inches long, & not the correct bend angle I need. Between this fuel neck welded onto the tank & the actual fill neck on the fender will be gas hose.
Does anyone have any recommendations other than just using steel pipe, & then coat it after welding for long term rust prevention ?
Thanks,
Mike.
Old 07-25-2012, 01:04 PM
SSedan64's Avatar
Aluminum pipe if you use a Hose at each end, Tank & Fendor. Stainless maybe?
Old 07-25-2012, 03:04 PM
35terraplane's Avatar
Gas tank neck
Originally Posted by Hot Rod Mike View Post
Hi guys,
Thanks,
Mike.
You said you were putting the gas tank behind the seat, are you putting it inside the car. If so I don't believe that is legal or safe. They took them out of P/U trucks years ago when they were behind the seat.
My "Tanks" tank is way up under the car in my 33, I have the filler go up though the trunk and comes out righ where the roof comes down, I have a power door on it.
Bob
Name:	gas door 33.JPG
ID:	67005   Click image for larger version
Name:	front end valley grille 2.JPG
Old 07-25-2012, 04:05 PM
gas tank
35 terraplane,
I have seen countless 33/34 fords w/the tank behind the seat. I forgot the guys name who posts frequently here w/a 32 Duece, & he has his tank behind the seat, too. Even the guy who called himself Scooter that did the Project 33 web build put an aluminum fuel cell behind the seat (project33.com). I would think that most people who build hiboys would put the tank in the trunk area.
Legal ? Don't know 'bout that. But you are correct that many old cars had tanks behind seats. I know a friend of mine's mid 60's GMC pick up does, & he still drives it occasionally.
I'm going to check w/Tanks Inc tomorrow & see what they say.
Thanks,
Mike
Gas Tank Filler Neck options? JhnBrackett Body - Exterior 10 09-05-2011 09:40 PM
Is this Gas Tank neck bad? Tank? Clean it? Leave it? gotmud Engine 1 07-06-2011 12:43 PM
Gas Tank filler neck HaydenP Hotrodding Basics 3 06-14-2011 11:56 PM
gas tank neck fiddyfofoad General Rodding Tech 4 08-23-2008 02:53 PM
Not sure which board is best? Gas tank neck? grumpy1 Engine 6 11-26-2007 07:38 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
