gas welding sheetmetal vs. mig - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-02-2004, 08:30 AM
I'm very interested in this 20 gauge wire. Do you know who carries it?
I am having a heck of a time welding sheet metal. I am a novice welder with a new Hobart Handler 175. I run C25 and have .025 wire. No matter what, I blow through. I finally am getting the knack of doing tons of tiny spot welds, however my spot welds are just that, tiny! They are half the size of the ones pictured in the above post. I experimented with all different wire speeds at the voltage rate '1' on my welder. I get least blow through at a feed rate of around 12-14. Should I attempt to go jump the voltage to '2'? I would think that more voltage would just cause greater blow through?
Any advice would be greatly appreciated, I am getting very frustrated. I spend more time filling holes that I blew through rather than welding.
thanks,
kev
  #17 (permalink)
Old 06-04-2004, 01:35 PM
THIS REPLEY IS NOT ABOUT ACTUAL MIG WELDING BUT THE QUESTION I HAVE IS THIS. I AM ABOUT TO PURCHASE A MIG BUT WOULD LIKE SOME IMPUT ON BRANDS AND QUALITY. I HAVE BEEN READING ON HOBART , MILLER, LINCOLN AND DID SEE IN LAST MONTHS EDITION OF EASTWOOD CATALOG THEY HAVE A COOL LOOKING MIG WITH CART FOR A PRETTY GOOD PRICE. I BELIVE THE BRAND IS CLARKE.. DOES ANYBODY HAVE ONE OR HAVE YOU HEARD ANYTHING ABOUT THE WELDER. I JUST NEED A GOOD 110 BECAUSE I DONT DO HEAVY WELDING ANYMORE AND JUST NEED SOME THING FOR A PANAL OR FIX IT UP PROJECT. I APPRECIATE ANY INFO YOU HAVE..... THANKS NO SHIFT...
  #18 (permalink)
Old 06-04-2004, 07:26 PM
Just a suggestion on MIG welding very thin sheetmetal try reversing the polarity and using some .024 solid wire using C-25.
  #19 (permalink)
Old 06-04-2004, 11:29 PM
starquest,
when I bought my Hobart 175 a month ago, it came with the flux-core wire and polarity was set up for this wire. Are you sure you are welding with correct polarity set like Tmod suggested?
I welded 3 patch panels in my 69 El Camino (2 on floor and 1 on firewall) with the 0.030 Hobart supplied flux-core wire. Voltage set at 1 and wire speed at 10. Lots of spatter, but it was fixable. You probably know the trick of spot welding thin sheetmetal, cooling it and working on opposite sides etc. Hundreds of small spot welds.
Today I bought the C25 bottle with the 0.030 Twenty gauge wire ($10 for a 2 lbs spool) to try this now on the thin firewall. I have a bunch of little holes to patch up. Like you I am curious how well this wire will perform.
Guys,
welding outdoors in a wind with gas, is probably a bad idea, right? What pressure will you recommend for the gas (15-20cfm)?
Thanks!
Denis
  #20 (permalink)
Old 06-05-2004, 12:42 AM
I do a lot of mig welding and you want it at about 20 and try to block the wind as much as possible or the wind will blow you shielding gas away giving you a porous weld.
Hoped this helped.
  #21 (permalink)
Old 06-05-2004, 09:03 AM
Great, thanks for the reply!
  #22 (permalink)
Old 06-09-2004, 07:48 AM
Randy,
I take it you weld from the outside and do you up the amps on the mig to get a bigger "drop through" so that the bead looks the same from both sides?
Hellz
