Getting butt welded sheet metal joints smooth - Page 12 - Hot Rod Forum : Hotrodders Bulletin Board
  #166 (permalink)
Old 01-22-2017, 10:49 AM
put up or shut up
Originally Posted by Schroeder View Post
I did do a rough trim 123pugsy, but I didn't do that close. Maybe that's the problem. Will the snips be able to make hard corner turns in material (like a scissors) when I leave only a little bit? Probably just have to go out and try it right now!!
Sent from my SCH-I545 using Tapatalk
that's exactly what it is. When making hard turns or circles I find the reds in my left make left hand turns better. I still find my reds make better right hand turns in my left hand but according to some people that's wrong, but there's plenty of people out there who agree with both. Feel free to try all the different combinations and do what's most comfortable to you. Do a google search on it and you'll see there's plenty of forums where this is discussed.
  #167 (permalink)
Old 01-22-2017, 12:43 PM
NEW INTERIORS's Avatar
life is a temporary assignment
Originally Posted by tech69 View Post
go search it out yourself. There's plenty of people out there that agree and disagree. It doesn't matter to me what you think, it's the internet.
As I said, I must be doing something right if those are the results. Keep chirping. You just sound like a hater.
LOL... No reason to hate you... That's funny.. Just like giving the right information to people.. To the OP.. Sorry for the hijack thread.. I'm done with this.. Back to the shop..
  #168 (permalink)
Old 01-22-2017, 02:00 PM
put up or shut up
if you got no time for this you should have left your opinion and moved on, just as I had. I didn't attack your comments til you butted into mine.
The work speaks for itself. I must be doing something right. I bet that makes you mad too.
  #169 (permalink)
Old 01-22-2017, 05:40 PM
https://cloud.tapatalk.com/s/58855081...22_182828.jpg?
Finally looked at my compressor to answer questions about my compressor. It's belt driven. See the bullet points on its label. Output pressure is about 80-90psi. Just doesn't have enough volume it seems. A little doe grinder gets starved easily. Again, it's 60 gallon and 6.5HP. just fyi
The Following User Says Thank You to Schroeder For This Useful Post:
123pugsy (01-22-2017)
  #170 (permalink)
Old 01-22-2017, 08:58 PM
Originally Posted by 123pugsy View Post
As I mentioned, you want a cheap electric shear for rough/large piece cuts.
You use the electrics up to the point that there is 1/8" to 3/16" left over. The hand snips will cut thru like butter then.
Your purchase is just fine. Hog out all but a wee bit and then trim very nicely.
This is my electric shear and it was very good money spent. This isn't a cheapie but you get the idea. I was cheap in how I got it, had an old tool box I traded the tool truck guy for it.
The other one is a "shear" (forget the real name) for cutting large sheets smaller that works real well too. I forgot where I got it. But I made a bracket to mount it in the vice.
ID:	341034   Click image for larger version
The Following User Says Thank You to MARTINSR For This Useful Post:
Rip VW (01-23-2017)
  #171 (permalink)
Old 01-23-2017, 03:49 AM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Wow.
I've never seen a roller shear before. What kind of sheet metal man am I? I hang my head in shame.....
How does that work? Is it a chore to cut with or does the handle pull thru easily?
  #172 (permalink)
Old 02-04-2017, 07:39 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
i still have a tool box full old metal tools. hand shears and flangers man you had to have some strong arms back then. i can barely use them any more. .
  #173 (permalink)
Old 02-05-2017, 04:52 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
I had a quick job to do yesterday and got out my old (red) snips started cutting and remembered this thread. I gotta get me a new pair of snips my hands are sore. my wrist too. This work don't need to be this hard.
  #174 (permalink)
Old 02-05-2017, 05:57 AM
123pugsy's Avatar
Wiki Edits: 29
Maybe it's not the snips, maybe you're getting old.
Disassemble the snips completely and try to sharpen the blades with a small angle grinder. You may get yourself a free set.
  #175 (permalink)
Old 02-05-2017, 08:00 AM
I think my brand new midwest snips r hard to use on 18ga steel. They're rated for it too.
  #176 (permalink)
Old 02-05-2017, 04:50 PM
For radius cuts, a good nibbler is hard to beat, and doesn't make your hand sore. (unless you get one of those "devils horns" stuck in it)
  #177 (permalink)
Old 02-10-2017, 05:55 PM
Hey we're on the topic of rust repair so this is loosely related: I have a roof on a 77 TA that I planned on pulling. The skin has some light surface rust on top. It doesn't appear to be anything I won't be able to get off with a light dusting of a grinder. The inside of this same spot concerns me. I wonder if there is any more of this on the inside of the roof skin tucked away out of view behind the inner roof structure. Does this warrant a roof skin repair as well? I'm really, really, really, really trying to avoid that. Did I mention that I'm trying to avoid that? Take a look and let me know.
Sent from my iPhone using Tapatalk
  #178 (permalink)
Old 02-11-2017, 08:01 AM
  #179 (permalink)
Old 02-11-2017, 08:26 AM
Wiki Edits: 11
I've had these forever and they've been pretty good snips for what they are (Task Force from Lowes) what I need is another pair of aviation snips. You may be on to something though Puggs, my grip aint what it used to be.
  #180 (permalink)
Old 02-11-2017, 08:27 AM
Wiki Edits: 11
Your roof looks pretty solid to me.
Sheet metal jltgator Body - Exterior 2 05-30-2013 07:02 AM
sheet metal camarossrs56 Introduce Yourself 4 08-22-2007 07:48 AM
Which way should welded metal warp? modas Body - Exterior 13 10-25-2006 06:34 PM
Help!! Welded sheet metal is warped fordSR Body - Exterior 3 09-29-2005 02:32 PM
Can galvanized sheet metal be MIG welded Slickriffs Body - Exterior 9 09-16-2004 07:19 AM
