Getting butt welded sheet metal joints smooth - Page 13 - Hot Rod Forum : Hotrodders Bulletin Board
  #181 (permalink)
Old 02-11-2017, 08:46 AM
Originally Posted by deadbodyman View Post
Your roof looks pretty solid to me.
DBM, take a look at the 2nd picture. Do u c the rust under the inner structure. It's on the backside of the surface rust on the top of the car. Other spots that look just like the surface rust on the outside of the roof skin as showed in the 1st pic do NOT have that bad rust flaking on the inside or I can not see the backside to verify.
Right now I plan on wire wheeling all the bad flaking rust away from the inside of the roof skin, but I don't wanna put a $13k paint job on this, have it bubble up, and have to replace a roof skin later.
Sent from my SCH-I545 using Tapatalk
  #182 (permalink)
Old 02-11-2017, 08:54 AM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Tough call.
Condensation occurs inside a car during the cool nights is what causes that.
If it's flaking, I would be leery on using that as well.
So, if it needs to come off to change a new skin, it would be off and you could try cleaning it up before buying a new one. A coat of epoxy would put a stop to it rusting again in the future.
  #183 (permalink)
Old 04-01-2018, 08:37 PM
Hi guys, new here and my first post. Quick tip for not over grinding welds. I work in high end art fabrication, ( museums, public art, and private collections). To not over grinding welds. Before you start grinding cover all welds to be ground with blue painters tape. Press tape into the contour of the weld. Start grinding, and the tape will come off only on the weld. If the tape comes off anywhere but the weld your angle is to steep. Grind until you barely see the tape beyond the weld start coming off. I usually start my weld grinding with a right angle air tool with a 3M Roloc disc, 40 or 60 grit.
That's my tip...thanks
1972 International Harvestor 1210 pickup
The Following 2 Users Say Thank You to Blacksmith_Friday For This Useful Post:
MARTINSR (04-01-2018), Supercharged03 (04-03-2018)
  #184 (permalink)
Old 04-01-2018, 08:41 PM
Interesting, I will give that a try. I usually just watch the metal being hit around it and adjust accordingly. But I will give that a try and see how it works out, thanks.
  #185 (permalink)
Old 04-02-2018, 05:25 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
machinist blue dye works well .
The Following User Says Thank You to shine For This Useful Post:
MARTINSR (04-02-2018)
  #186 (permalink)
Old 04-02-2018, 12:51 PM
put up or shut up
i use a thick cut off disk with a light attached to my head. Can see everything going on. once it's cut down I get the die grinder and blend it in a little.
  #187 (permalink)
Old 04-02-2018, 04:01 PM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
That's slick .... thanks I will use it.
Greg
  #188 (permalink)
Old 04-03-2018, 05:50 AM
farna's Avatar
Member - AMC/Rambler "guru"
Last wiki edit: AMC V-8s
Wiki Edits: 14
Didn't read every post, so if this has been mentioned....
As far as the welder not liking 0.023" wire, try getting new roller wheels. You've probably used so much 0.030" wire that the wheels have a bit of a groove in them, just enough to not grip the smaller wire well. Try taking the tension off the rollers when done if the welder is stored for a long time between uses, just don't forget to check tension before you start welding.
Sheet metal jltgator Body - Exterior 2 05-30-2013 07:02 AM
sheet metal camarossrs56 Introduce Yourself 4 08-22-2007 07:48 AM
Which way should welded metal warp? modas Body - Exterior 13 10-25-2006 06:34 PM
Help!! Welded sheet metal is warped fordSR Body - Exterior 3 09-29-2005 02:32 PM
Can galvanized sheet metal be MIG welded Slickriffs Body - Exterior 9 09-16-2004 07:19 AM
