Getting butt welded sheet metal joints smooth - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 01-01-2017, 10:28 AM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Mike, I'll have to disagree. Hobby guys are not in the auto body business.
My answers above are for the original post and the title of this thread.
Get the TIG out and start practicing so you can get smooth butt welded joints.
BTW, the most important part of using the TIG has nothing whatsoever to do with welding.
You will be forced to make your patch panels properly without gaps.
Even with MIG, you are toast if you have huge gaps.
Taking time with fitting panels nicely, no matter the welding type, will be time saved 10 fold.
Most guys rush this and end up paying for it in time wasted trying to get all those cracks and gaps filled. Then they need to work out the oil canning, etc....
  #32 (permalink)
Old 01-01-2017, 10:31 AM
Yup. I'm in the "most guys" and that's why I'm here. I've done patches before where I really thought I was meticulous and took my time, but the results were little better than what was shown here. I guess it's something I really, really, really need to practice. The patch fitment with zero gap seems unobtainable for me at the moment.
Sent from my iPhone using Tapatalk
  #33 (permalink)
Old 01-01-2017, 10:44 AM
123pugsy's Avatar
Wiki Edits: 29
Not unobtainable if you cut less material out and sneak up on it slowly.
This is where you need to spend more time.
  #34 (permalink)
Old 01-02-2017, 07:01 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
I'll agree with that, Puggs. Your a great tig welder so let me ask you one question: What did you start welding with? and how long have you been welding. I can tell you didn't just go to HF and pick up a tig a month ago to get welds like that. most likely you've been doing it all your life. Remember back when you started Tigging now try to imagine how tough it would be to learn without someone right there to show you what your doing wrong and adjusting the machine for you. It takes time to learn and a lot more time than mig welding does. Mig welding does a good job Tig is over the top good as far as doing body panels goes and a tig is just not needed for this kind of work.
I believe I already stated that metal and "joint prep" are the most important part of ANY type of welding. Most hobbiests wont have things like a tig and a lot are lucky to have a mig. if they have a mig they are serious hobbiests.
knowing the machine is half the battle especially when you start having trouble.Things like the liner, drive wheels, wire and tip size are all things that will get you a better weld. Basicly Im saying that you CANT jump to Tig until you master the Mig and the weld itself. How are you going to be successful at Tig welding if you don't even know what a good weld looks like?
  #35 (permalink)
Old 01-02-2017, 07:15 AM
123pugsy's Avatar
Wiki Edits: 29
I was self taught TIG welding at lunch time at work.
It's actually quite easy.
The reason I finish my welds as I do is because on stainless you cannot leave any divots.
The OP states he already has a TIG. A little shove may get him to dust it off and check it out.
If anyone ever has a question about it, I'm all ears and willing to offer the little bit of theory I know.
And of course, you're correct, fit, fit FIT!!!!!!!
Get them fitting nice and the welds will be better.
  #36 (permalink)
Old 01-02-2017, 07:29 AM
Wiki Edits: 11
yes absolutely, sneaking up on it is the way to go.
You cant get a perfect fit by measuring. measuring is for the rough fit then you sneak up on it. heres a few pics of what I've been talking about.
ID:	337266   Click image for larger version
ID:	337274   Click image for larger version
ID:	337282   Click image for larger version
ID:	337290   Click image for larger version
  #37 (permalink)
Old 01-02-2017, 07:47 AM
Wiki Edits: 11
Pic # 1&2 Shows rough patches, they overlap the panel and are screwed down tight. BTW,I like to epoxy prime all my patches before welding.
Pic#3 Shows Tabs to hold patch and a mig welded patch in jamb
Pic #4 the jamb patch weld ground down not real pretty but it will be getting a thin coat of filler and primer.
Pic #5 Shows an overlapped patch marked with a sharpie for final trim. (sneaking up on it)
  #38 (permalink)
Old 01-02-2017, 08:15 AM
Wiki Edits: 11
Heres some more pics
ID:	337354   Click image for larger version
ID:	337362   Click image for larger version
ID:	337370   Click image for larger version
ID:	337378   Click image for larger version
  #39 (permalink)
Old 01-02-2017, 08:31 AM
Wiki Edits: 11
Sneaking up on it
Pic#2 wheel arch patch is off so I can cut off bad metal I use my cutoff wheel for this. Taking care to cut on the right side of my line. When I'm done I can still see the sharpie line.
Pic #3 curved lines are a little tougher, this shows the middle is a little tight and needs some trimming it sure is handy to be able to screw the patch on for this kind of work.
Pic #4 Close enough for the Mig. ready to weld.
pic# 5 weld with single spots every few inches cool with air blower about every 3 welds. You don't want the work area to get too hot so take breaks when welding but weld these spots until the whole joint is done. if you don't weld all the way and have spaces between the welds you'll see the joint after painting as a ghost seam.
  #40 (permalink)
Old 01-02-2017, 08:45 AM
Wiki Edits: 11
I've run out of time but when I get back I'll go over how to grind and dress your welds
ID:	337402   Click image for larger version
ID:	337410   Click image for larger version
ID:	337418   Click image for larger version
ID:	337426   Click image for larger version
  #41 (permalink)
Old 01-02-2017, 09:16 AM
WOW! Thanks for posting all the pics. Definitely helping me and hopefully others doing similar searches on the internet. Can't wait to see what u have 2 say about grinding and dressing welds. The finished product suggests you have that down to a science.
  #42 (permalink)
Old 01-02-2017, 09:19 AM
Btw, I spent my entire Christmas break expanding and mini tub, grinding it, and TIGing the weld shrink zones down. As someone suggested a couple posts ago though, I am going to cut it all out and make a new patch. I guess learning fitment is a slow, painful process when you're not careful. Hopefully it pays big dividends though. You guys have convinced me to take this route as I believe it to be the "right" way to proceed.
  #43 (permalink)
Old 01-02-2017, 10:20 AM
Originally Posted by prpmmp View Post
Hey new here! Will do an introduction later(pressed for time) Here is a thread from another site about butt welds,Its long but great information and explained well by Robert!! Hope this helps! Pete MP&C Shop Projects - The Garage Journal Board
Very good stuff, it's as simple as that!
  #44 (permalink)
Old 01-02-2017, 02:15 PM
Wiki Edits: 11
I went to tec school just to learn tig but had to basicly waste the first year doing oxy /act cutting and then arc followed by mig all of which I had been doing for the past 35 years theres things like keeping you tungsten sharp that are ez to learn but take forever to figure out without someone to show you. I cant imagine anyone who has never welded picking up a tig and welding without guidance. I know I couldn't have done it without my welding experience on other types of welding. heck I still cant gas weld with steel rod to save my life and I tried and tried I just cant do it. I had a body shop in Fla. that was in the back of a muffler shop and that's about all they did was gas weld he could weld the top side of a muffler pipe that he couldn't even see just as well as the bottom, I couldn't even gas weld a flat piece of steel on a table. some people have it, some don't. luckily there is no gas welding on cars and welding itself is just a small part of body and paint work.
The most valuable lesson I learned at welding school is I love to weld.....for about 10 min.. after that I pretty much hate it, it took 2 years of school to learn that. I'll never be a welder.
The problem I have with Tig is I cant weld a panel without warping it slightly so instead of warping panel after panel until I get good enough I just stick with the mig and can weld a patch dead center of a hood or roof with absolute Zero warpage and usually just a skim coat of finishing putty and primer finishes it up for paint.
Sorry for all the long posts but its been cold and raining for two days and I don't have anything better to do.
The Following User Says Thank You to deadbodyman For This Useful Post:
123pugsy (01-02-2017)
  #45 (permalink)
Old 01-02-2017, 02:18 PM
Wiki Edits: 11
OK, One more question for you Puggs. You say you were self taught but how long ago was that? Your welding looks like you've been doing it for many years. Way past my Tig skills
Sheet metal jltgator Body - Exterior 2 05-30-2013 07:02 AM
sheet metal camarossrs56 Introduce Yourself 4 08-22-2007 07:48 AM
Which way should welded metal warp? modas Body - Exterior 13 10-25-2006 06:34 PM
Help!! Welded sheet metal is warped fordSR Body - Exterior 3 09-29-2005 02:32 PM
Can galvanized sheet metal be MIG welded Slickriffs Body - Exterior 9 09-16-2004 07:19 AM
