Getting butt welded sheet metal joints smooth - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 01-06-2017, 06:36 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
Originally Posted by Schroeder View Post
Deadbodyman, in regards to your choice of 3m sanding roloc doscs, do you use the green corps series? Can you give any more information- possibly part numbers- on the discs and stones? I'd love to pick some up on amazon tonight yet and give em a go this weekend.
From my initial searches on the internet the 3m stuff is priced way higher than what I use now. This is to be expected with their brand, and I'm fine with it IF their products do end up lasting longer and are better quality. That being said, do you have a good source to buy these expendable items from in bulk?
Sent from my iPhone using Tapatalk
I'll get you the part numbers and get back to you tonight, but if you like the flap wheels just wait till you try the stones. Night and day
  #77 (permalink)
Old 01-06-2017, 12:52 PM
Wiki Edits: 11
Well, I wrote down the part number for the stone and promptly left it on my desk but I took some pics and its on there, but you cant see the last number which I believe is a 1 so the stone is 01991. the roloc grinding discs are also green corp but Norton (the blue one) makes some awesome ones. These three tools will get you started grinding and dressing your welds as you get better you may want to add more and try other brands but these are the basic tools I use to grind and dress.
ID:	338034   Click image for larger version
ID:	338042   Click image for larger version
ID:	338050   Click image for larger version
ID:	338058   Click image for larger version
  #78 (permalink)
Old 01-06-2017, 01:18 PM
Wiki Edits: 11
How I grind and dress my welds
I don't have anything being welded at the moment so I decided to go ahead and show you how I grind a weld and dress it. Keep in mind I picked up some scrap off the floor and Im only doing a quick overview so you get the idea but this is actually good enough for most and certainly filler ready.
Grinding weld starts with the weld itself so lets start at the very beginning (setting up the machine)
Step 1
The wire and drive wheel.
In the first pic you'll see the drive wheel with two grooves Ive got it set up for 030 wire so the drive wheel is set so the wire goes in the grove marked 030. If I wanted a thinner wire all I do is flip the wheel around and use the wire that side shows which is 020-023 I believe. then you check the tip and make sure it is marked the same as the wire 030.
Step 2
Heat and wire speed, Dialing them in.
set your gas at 20 , too much gas wont effect the weld but too little will. dial that in later.
Get some scrap that's the same gauge and set the heat about half way and the speed anywhere lets say 1 ,hook up the ground and pull the trigger. Most likely the wire will melt all the way up to the tip set it all the way up and itll jab the torch out of your hand so turn the knob until it makes the sizzling bacon sound and that's the perfect setting for the #5 heat setting.
do a few spot welds and next we see if that's the setting for the metal gauge you want to weld, this is only the setting for #5 heat not the metal your welding.
ID:	338074   Click image for larger version
ID:	338082   Click image for larger version
  #79 (permalink)
Old 01-06-2017, 01:39 PM
Wiki Edits: 11
looking at the third pic I started on the right side row and and on the left side top is where I stopped .that's what it should look like. Not to high but a little proud and almost flush. That one single spot weld sitting all by itself between the practice welds and the joint was just to make sure the settings are right
  #80 (permalink)
Old 01-06-2017, 02:02 PM
Wiki Edits: 11
once the seam is welded grind the weld only. grind it down until its almost flush. the weld is ground but not the surrounding metal set the air pressure so the grinder works well at the lowest pressure and not winding out because you don't want it making heat, you'll warp the work. Keep the stone square to the weld and never use the side. pic $ shows the weld just about ready for the grinder.
ID:	338122   Click image for larger version
ID:	338130   Click image for larger version
ID:	338138   Click image for larger version
ID:	338146   Click image for larger version
  #81 (permalink)
Old 01-06-2017, 02:24 PM
Wiki Edits: 11
weld is ground ready for dressing with the brown roloc cookie.
last pic is the back side of the weld.
ID:	338170   Click image for larger version
ID:	338178   Click image for larger version
ID:	338186   Click image for larger version
ID:	338194   Click image for larger version
The Following 2 Users Say Thank You to deadbodyman For This Useful Post:
123pugsy (01-06-2017), 35prog (11-22-2017)
  #82 (permalink)
Old 01-06-2017, 02:29 PM
Wiki Edits: 11
To see if you've made a good and proper weld bend the metal back and forth to see if the weld breaks or the metal tears, if the weld don't break its good to go. I forgot to count but it took about 10 times back and forth to break apart. Now your ready to weld with confidence.
The Following 3 Users Say Thank You to deadbodyman For This Useful Post:
123pugsy (01-06-2017), MARTINSR (01-06-2017), NYTrainer (01-29-2017)
  #83 (permalink)
Old 01-06-2017, 05:04 PM
Good concise expaination Mike. There will be a lot of people get good results folowing your example. Also, you were correct about the numbers. The 3m 1/16 cut off wheel is 01990 and the 3/16 you are using in the photo is the 01991 part number.
Also just in case you were wondering I had left over Lasania lunch today.
John
  #84 (permalink)
Old 01-06-2017, 08:55 PM
Good stuff there Mike.
  #85 (permalink)
Old 01-06-2017, 10:57 PM
put up or shut up
just keep practicing, pay attention to what's going on, and make slight adjustments. In no time at all you'll be welding like the pros.
Here's my latest masterpiece.
  #86 (permalink)
Old 01-07-2017, 05:10 AM
Thanks so much everyone for all the replies. Special thanks to deadbodyman. U have a lot of time in posting pics, typing, and getting part numbers for me. I appreciate it. So the 01991 is a "stone" and the 01990 a cut off wheel it looks like?
Use cut off wheel of stone 1st then roloc disc then abrasive pad. Use 36 grit everything. This will be big help for me. I'm going to start redoing my wheel well today.
  #87 (permalink)
Old 01-07-2017, 06:55 AM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Post some pics of your new patch.
A little further away this time though, ha....
  #88 (permalink)
Old 01-08-2017, 06:05 AM
Wiki Edits: 11
John
John, If theres no pics it didn't happen, and its a good dang thing you'll never catch me correcting anyone spelling and puntuation LOL.
I was a bit rushed the other day when I posted. I just wanted to add something about the welds.
In my post #81 second pic, theres a few spot welds showing you can also control the size of the weld with the heat and wire speed.
Starting at the far right I had the the setting at 5-7 and as I went to the right I lowered the settings. I like doing hot, quick tacks which will also get you a smaller weld you can control the size by how quick you can trigger.
The Following User Says Thank You to deadbodyman For This Useful Post:
John long (01-08-2017)
  #89 (permalink)
Old 01-08-2017, 06:27 AM
Wiki Edits: 11
Yes a bit father away would be better. Something else I found is my cameras flash glares a lot of close pics so I just cover it with my finger.
  #90 (permalink)
Old 01-08-2017, 06:50 AM
Wiki Edits: 11
Attachment 338314
Your welding skills have improved 100%, Henry. Now I think your ready try it with the gas on.
Next year we'll get your Tig down off the shelf and give that a go.
Sheet metal jltgator Body - Exterior 2 05-30-2013 07:02 AM
sheet metal camarossrs56 Introduce Yourself 4 08-22-2007 07:48 AM
Which way should welded metal warp? modas Body - Exterior 13 10-25-2006 06:34 PM
Help!! Welded sheet metal is warped fordSR Body - Exterior 3 09-29-2005 02:32 PM
Can galvanized sheet metal be MIG welded Slickriffs Body - Exterior 9 09-16-2004 07:19 AM
