"glue" removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2018, 01:53 PM
"glue" removal
I've yet to find anything that will effectively remove the crap left behind by vinyl door edge guard mouldings.
I dunno what that chewing gum crap is, but I have yet to find a solvent that will cut it.
Old 12-06-2018, 07:35 PM
Rip VW's Avatar
I will endevour to persevere
Last journal entry: This thread is officially Kaput as of 11/07/2017
Going out on a limb here get you some "Goof Off" to remove the guck. Test it on a inconspicuous area of painted surface to make sure it won't eat the paint. My old model T had an enamel paint and I found if I swiped the surface quickly and very lightly the gunk would come right off. if I rubbed hard the paint would then start to show abrasion..
That stuff works on a lot of things for removing sticker glue to body adhesive..
Old 12-06-2018, 07:45 PM
Rip VW's Avatar
Old 12-06-2018, 08:09 PM
If it's been painted in the last 30 years or so it's likely urethane maybe even basecoat clear coat. If that's the case lacquer thinner can be used to remove that goop without damaging the paint. Do a little test where you can't see it just in case.
The Following 2 Users Say Thank You to MARTINSR For This Useful Post:
22george (12-08-2018), Rip VW (12-07-2018)
Old 12-08-2018, 07:36 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
A eraser wheel in a drill at slow speeds takes it off easily
Like this
https://www.amazon.com/Astro-400E-Pi.../dp/B000IHK2TY
The Following User Says Thank You to jcclark For This Useful Post:
Old 12-08-2018, 09:23 AM
cozwurth's Avatar
Last journal entry: Vinyl top carnage...
Like this
I was thinking the same thing! I'm also wondering how one of those will work on removing RTV type sealant around the windows on a camping trailer...
Dave
Old 12-08-2018, 10:09 AM
Yep, I was thinking "glue" but the foam tape left from those mouldings, jc is right on the money the eraser wheel is the way to go.
The Following User Says Thank You to MARTINSR For This Useful Post:
Old 12-08-2018, 01:10 PM
justold's Avatar
Dave
The RTV can be removed with a product called Release sold in the boat stores .I think it is made by
star Brite .
The Following User Says Thank You to justold For This Useful Post:
Old 12-10-2018, 11:18 AM
It's not like anything I've run across. Eraser won't work,(just gums up) Laquer thinner, goof off, w&g remover,(won't touch it) grinder,(gums up like eraser, and wire brush) heat gun, (makes it even more gooy and harder to remove) Wire brush... all won't do it. It's not double sided tape, like a side molding, it's some sort of snot-like substance that's used inside cheapo plastic door edge guard. The paint on the vehicle is original '86 Ford paint. And I suspect the edge guard has been on it since '86 as well.
I managed to get it off (kinda) with torch, and just burning it off. (painting anyway) Once it's burnt to ash, it comes off easily.
Headliner spray glue overspray removal Doug427 Interior 4 07-12-2016 01:37 AM
"Glue?" Instead of weld patch panels? The Mopartist Body - Exterior 3 04-18-2007 01:48 PM
dash glue removal excaliberprime Interior 16 03-27-2007 10:01 PM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 12:44 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
