GM 10 bolt, 14 bolt, Ford 8.8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2020, 12:30 PM
I have a 1995 C1500 single cab with a built 355, 2wd NV3500. I just installed a limited slip Yukon 3.73 differential in the factory 10 bolt. I’m good for now, but plans in the future are a pretty stout 383 with some spray. So I’m planning on that. What’s the GM 10 bolt good for power wise?
I found a local guy selling a GM 14 bolt out of a 2500 for pretty cheap. Probably a dumb question but Will the same Yukon limited slip fit?
For the upgrade, would y’all choose the 14 bolt or the Ford 8.8? Or is there a way to just beef up the 10 bolt? Daily driver/weekend cruiser truck.
Old 07-25-2020, 12:50 PM
ericnova72's Avatar
More for Less Racer
14 bolt is completely different, no parts from the 10 bolt will fit it.
The 8.8" Ford and the 30 spline 8.6" 10 bolt in your truck are roughly the same strength, and with the Yukon diff you've got a stronger assembly that any stock 8.8" ford with the weaker factory Traction-Lok diff.
I'd keep what you've got, add better aftermarket axles like Moser, Dutchman, Strange, or Mark Williams, and add a aluminum rear girdle cover and go with it.
It'll take more than a 383 on 300Hp spray to bust it then. If you do break it after that, I would not consider the 14 bolt or the 8.8" Ford as upgrades....go to either a 9" Ford, or Dana 60.
I'm assuming when you say 14-bolt, you are talking about the 9.5" ring gear 14-bolt with semi-float axles(6 bolt wheels), and not the 10.5" ring gear full-floating model (8 bolt wheels)
Old 07-25-2020, 12:54 PM
the 8.8 is not an upgrade from the 8.5 30 spline.
the 14 bolt 9.5 is much stronger.
the diffs do not interchange.
on the street with radial tires I wouldn't be worried about the 8.5.
Old 07-25-2020, 01:17 PM
64nailhead's Avatar
X2 on putting a good set of axles in your 8.5/8.6 10 bolt. The axles are the weak link if you have a 30 spline center section.
I have a car that makes 800 whp all day on an 8.5 that has a 30 spline center with Moser axles. Been through Drag Week and 10k+ miles of driving and 5 sets of tires in that time frame at 3700lbs. You'll be fine with an axle upgrade. Axles are cheap in the big scheme of things IMO.
The Following User Says Thank You to 64nailhead For This Useful Post:
lmsport (07-25-2020)
Old 07-25-2020, 01:45 PM
The GM axles are better than the Ford axles, and for the drag strip aftermarket axles are mandatory. On the street, not so much as the 95 models have 30 spline.
The 8.8 and the GM 8.5 share the same bearings. The 8.5 has smaller carrier bearings, same as the GM 7.5 and Ford 7.5.
The 9.5 is GM version of a Dana 60 and will take alot of abuse, but they tend to have heavy cases and thick axle tubes making them rather heavy.
Old 07-25-2020, 02:17 PM
Great! I’m glad to hear I can keep what I have and just run some axle upgrades! Music to my ears a for sure. I know Yukon makes some axles as well. They claim to be 25% stronger than factory replacements. Anyone have an opinion on them? Mosers seem like the highest quality from what I heard/read. A little pricey though at 500 a set.
Old 07-25-2020, 03:12 PM
BuzzLOL's Avatar
Cars, Trucks, Boats
About 5 years....................... LOL!
Old 07-25-2020, 03:35 PM
big gear head's Avatar
High Performance Rear Ends
I would be more worried about the NV3500 giving up.
Old 07-26-2020, 08:42 AM
Yea I’m definitely pushing the limits on the little NV3500. I wish someone made a beefier aftermarket option. I’ll look into that a little further. I can’t decide if a TKO 600 is my best option or swapping to a T56.
Old 07-26-2020, 11:24 AM
If it was me I believe I would be using the TKO 600.
Old 07-26-2020, 01:05 PM
Sm465, and a 4.56 FF C/C 14 bolt in stock form will hold up to 600ft/lbs clutch drops until the clutch gives out.
I went through 12 tires(dually)on a c30 one summer on a to give you an idea.
The nv3500 in my 94 1500 daily the TBI motor is only pushing 330ftlbs. 350ft/lbs is about as much as a nv3500 can handle when it is being abused. The back tires are my "summer tires" to allow for slip over grip to save the junk rearend when I want to have some fun.
This is one of my stock unmodified rides still running stock rims etc.
I have others that are cut up or modified and they will never run a 3500.
A SF 14 bolt (88-98) with a 3.42 is going to be a easy (almost) bolt in upgrade and what I would go with if I was looking for a bit stronger axle without alot more weight.
With 3.42 ratios you do not need overdrive and can run a wider range of direct ratio transmissions. You can swap your hubs in the front and have a correct bolt pattern all around running factory rims.
Old 07-26-2020, 01:25 PM
1995 CHEVROLET C1500 Moser Engineering Replacement Alloy Axle Shafts A30-89GMTK
https://www.summitracing.com/parts/m...et/model/c1500
Old 07-26-2020, 03:44 PM
ericnova72's Avatar
More for Less Racer
The SM465 may be strong, but for a 1/2 ton 2wd street cruiser, or a street/strip truck it's a complete loser for a host of other reasons....extremely poor gear ratio spreads....and just try to speed shift one of those, it's not gonna happen with internal parts that heavy and slow to move
Old 07-26-2020, 06:30 PM
That is why you put a splitter behind it. Watson or gear vendors depending on what you can find. A 25% reduction splitter with solenoid shift will be like this.
3.58, 2.68
1.70, 1.27
1.0, 0.75
My watson with .72 between a sm465 and np205 will end up running these ratios.
3.58, 2.57
1.70, 1.22
1.0, .072
I don't think the sm465 ratios are that bad for a truck transmission.
You have a burnout gear that can allow even a 4 cylinder to smoke the tires.
A take off from a stop gear.
A drive from 15 to 60 gear.
Then a cruising gear.
If you want a highway gear then you throw a splitter behind it and you have a very tough transmission for a fraction of the cost of a "race" transmission that you can rebuild in a shed.
