GM power steering pressures - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2019, 05:58 PM
I have a LT1 from a 93 Corvette installed in a 50 Chevy Truck. All of that sits on a S-10 chassis.
The power steering pump is from the 93 Vette but I changed out the S-10 non power steering box to a GM quick steer power steering box . I started thinking about pump pressures and was wondering if this pump will work with the steering box. Do the GM pumps all run at the same pressures ?
While we are discussing steering I have another question. When I installed the power steering box, I had to change out the pitman arm. I have read some post that people mention a sleeve that should be installed at the lower end of the pitman arm where the steering link connects. Is this true and it so where can I find the part number? The steering linkage is all stock S-10
Thanks
Rick
Old 02-08-2019, 06:01 AM
75gmck25's Avatar
Last journal entry: Engine replacement
Based on what I've read over the years, I believe older GM pumps all run at similar pressures. The new Type 2 pumps do run at higher pressures, and there are pressure reducers and mounting brackets available. The biggest problems I've read about is when you mix Ford components and GM components, since pressures are much different.
Pitman arms are usually just one heavy duty piece of steel. My K25 has what is called an inner tie rod, which has an adjusting sleeve that allows you to center the steering wheel, and of course the outer tie rods adjust to set toe in.
Bruce
Old 02-08-2019, 09:27 AM
55 Tony's Avatar
I believe if your new P/S pitman arm is longer or shorter, you will also need to change the idler arm to a P/S one also.
Young enough to learn ... too old to remember.
Old 02-08-2019, 11:00 PM
CaptMike's Avatar
Capt Mike
If you are concerned that your steering system has to much pressure you can purchase a low cost replacement pressure valve from TURN ONE. They are the experts. I had to install this valve when I installed the LS1 & 6 speed in my '56 Chevy, which had Rack & Pinion steering. And She steered way to quickly !!
Read there Tech page and give them a call.
https://www.turnone-steering.com/blogs/tech-101
GM pump pressure and Flow rates are all over the chart !!
RE the Pitman Arm, you should try to keep the same OEM Height & Location where the drag link connects. Else you will have a Bump Steer problem and possible Ackerman change in Toe in when the wheels are turned in a corner as example.
Check the S-10 Forum for tech assistance..
The latter any line-up shop usually test during an alignment. They turn the wheels fully side to side and check the TOE changes.
Good Luck ..
Old 02-09-2019, 01:42 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
GM often used pressures in the 2300-2700psi for recirc-ball boxes and 1500-1800psi for rack and pinion. There was plenty of pump crossover, so you should be able to find the pressure regulator for the correct application and just screw it into the pump.
Old 02-09-2019, 01:59 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Pumps are set between 850 psi and 1500. Hydra boost additions take the higher.
Change the shims in the valve to adjust
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
joe_padavano (02-21-2019)
Old 02-10-2019, 12:51 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Thanks
Rick
Why did you have to change the Pitman arm?
Old 02-10-2019, 02:30 PM
CaptMike's Avatar
Capt Mike
Old 02-21-2019, 01:19 PM
The S10 did not have power steering. So I removed the steering gear box and installed a "quick steer" GM box . It did not come with a pitman arm. I could not use the pitman arm from the S-10 because it was a different diameter than the output shaft on the new gear box.
Thanks to everyone for the good info. I will check out the site posted.
Rick
Old 02-21-2019, 03:23 PM
Old(s) Fart
Last wiki edit: Wheelbase database
S-10s use the same length pitman and idler arms for both power and manual steering. The pitman needed to be changed because the output shaft on the power box has larger diameter splines than does the output shaft on the manual box. The only differences in idler and pitman arm length is 2WD vs 4WD.
Old 02-22-2019, 03:11 AM
64nailhead's Avatar
Regarding the pressures, I will say that you will be fine (minor guessing). I'm basing this on some personal info - I've been using type 2 pumps with gears designed for type 1 pumps for quite a while without issue , mostly. Paying attention to p/s pump speed and keeping it in the factory range via pulley size is miportant though. A large Gen1 crank pulley with a smaller than stock power steering pump pulley on a type 2 pump can create issue if you intend alot of time with the motor over 5000 rpm's.
Keep track of return line restrictions as well. I started a thread a while back due to a binding/sticking issue that was the result of a new reservoir I installed with too small of a return port.
Gm 454 Water Volume,static Pressures RONNIE CLAYTON SR. Engine 2 09-14-2009 06:02 PM
GM pressures CorvetteStripes.com over trademark issues Jon Hotrodders' Lounge 11 02-29-2008 04:04 AM
Power! -- No power? -- Power!!!! No Power???! Fragzem Engine 10 05-16-2005 01:30 PM
power steering pressures zeker6 Suspension - Brakes - Steering 2 05-23-2004 04:42 PM
Power Steering pump pressures Jag Daddy Engine 5 06-19-2003 12:15 PM
