GM Steering rag joint delete, replace with? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2019, 09:51 AM
I am searching for, but have yet to find a coupler to replace the rag joint for my 3/4" 30 spline steering box. I have found universals that will adapt to a 3/4 DD but I am trying to find a rigid connection for the steering box that I can secure about 6 inches of 3/4" DD shaft. If I can find a rigid steering box to 3/4 DD shaft thats about 4 to 6 inches long, I wont need three universal joints and the associated support bearing. I was hoping to find an off the shelf unit by one of the many vendors. Anyone seen anything like this?
Old 05-05-2019, 10:32 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I have never seen what you describe. I think you are going to wind up with the universal and support bearing.. Just my take..
Sam
Old 05-05-2019, 01:42 PM
ericnova72's Avatar
More for Less Racer
Have you looked at Sweet Manufacturing, they've got a bunch of 3/4-36 splined couplers that look like they are for Round and Double D shafting.
https://sweetmfg.biz/home.php?cat=71
Old 05-05-2019, 02:00 PM
dusterdude3404's Avatar
Jeep cherokee shaft
Sent from my LG-US601 using Tapatalk
Old 05-05-2019, 02:02 PM
Oops,if its an s10.not sure about anything else
Old 05-05-2019, 03:12 PM
https://www.summitracing.com/parts/brg-313100
Weld on 3/4 DOM tubing to make as long as required.
Old 05-06-2019, 04:58 AM
75gmck25's Avatar
Last journal entry: Engine replacement
Conversion to a Jeep Cherokee universal joint shaft is very common for about '79 and up GM trucks. Earlier steering boxes (like my '75) have a different fitting and the Jeep shaft will not fit. You may have to swap in a steering box that will work with the new steering shaft.
This Youtube video shows how it is done.
Bruce
Old 05-06-2019, 09:09 PM
Here is a 3/4 30 coupler that you can weld a 3/4 36 shaft, or a 3/4 DD shaft into at the length you want.
3/4" Smooth X 3/4"-30 (1" OD) Steering Coupler - FR1944 - 574 - 5366
Old 05-08-2019, 02:41 AM
Thanks for all the input. I have decided to keep the rag joint and reinstall the bearing support, I was hoping to delete the bearing support but it appears to be my best option at this time. All inputs much appreciated.
Wiring GM Tilt Steering Wheel Column texapache Electrical 7 10-15-2010 08:35 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
rag joint replacement on '78 ford granada Scott Newcomb Suspension - Brakes - Steering 1 10-13-2004 05:08 PM
Replace Steering U joint Dave E Shank Suspension - Brakes - Steering 1 08-13-2004 05:51 PM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 09:50 AM
