Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM Wiper Circuit
Old 08-16-2006, 12:14 AM
ElegantInventor's Avatar
ElegantInventor ElegantInventor is offline
Cubic Inches is King
Last journal entry: High Resolution Drawings
Shop Wiring Diagram for GM Wiper Switch
Elder Rodder,
Pete's effort was solid - it gets the basic functions OFF LO HI to a wiper motor such as the excellent unit you bought from Newport.
If your Buick switch tests out like Pete's -
you have two wires (on Pete's the violet and gray) that are:
not connected to ground for OFF
both connected to ground wire for LO
one not connected, and one is connected to ground for HI
Then Pete's circuit will work well. I took the liberty of drawing the circuit out complete with the proper fuses - thank you Pete for the inspiration.
My previous "black box" made the intermittent wiper variable delay and washer functions operable. It was very complex.
This circuit of Pete's is simple.
Jon P
