Going to try body work again, was this my mistake? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2014, 09:49 PM
Aleksey's Avatar
Founder @ Maintenr
Hey guys,
I'm trying to restore an older car, my prior attempts on the hood (I know it's not the easiest) part have failed the lighting test (you can see bondo edges, while I could not feel them to touch).
What I did before is sand it to metal with edges, bondo followed by sanding + and high grit until I could not feel the difference with fingers.
I think and correct me if I'm wrong, the issue was that after sanding the bondo I did not spray 2K high build primer on top of it and blend it again, that what makes it perfectly smooth even to the 'light' test.
Is this correct theory? I'm using a vinyl wrap on top of it until I can find somebody with a gun and booth for cheap.
Advise and suggestions are welcome.
Old 05-19-2014, 09:57 PM
carolinacustoms's Avatar
Automotive Extraordinaire
You should always spray a couple coats of a good 2K primer over filler (at the very least 2K, an epoxy would be even better) to fill any scratches left from sanding, as well as give something to feather and blend into the surrounding repair area.
Kelly
The Following User Says Thank You to carolinacustoms For This Useful Post:
Aleksey (05-19-2014)
Old 05-19-2014, 10:09 PM
Aleksey's Avatar
Founder @ Maintenr
Kelly
What grit do you recommend as a final blend to original paint?
Old 05-19-2014, 10:14 PM
If you are using a 2K urethane primer over the filler, I usually finish filler to 320 grit, then apply the primer. If you are using a "high build" primer you can finish the filler in 180-220 grit and should not have any trouble with scratches showing through. Once you get the primer on and it has dried, block it with 320-400 and then go to 600 as a final grit prior to paint. If you sand through the primer, you need to reapply over any sand through areas.
Kelly
Old 05-19-2014, 10:44 PM
Aleksey's Avatar
Founder @ Maintenr
Kelly
Thanks bud! Excited to give it another whirl.
Old 05-20-2014, 01:32 AM
milo's Avatar
point on positive
Feel with your whole hand not just your fingers... your palm will actually tell your fortune
Old 05-20-2014, 05:00 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
And throw that light out.....Sand it ,prime it, guide coat it......Then sand it again for paint....The guide coat will tell you everything...
The Following User Says Thank You to deadbodyman For This Useful Post:
AirwolfPJ (05-20-2014)
body work Windy Body - Exterior 1 03-13-2013 10:47 AM
Body work etc jd71cam Body - Exterior 6 10-27-2011 04:55 PM
body work jasrking Body - Exterior 1 10-22-2007 02:04 PM
Lill Bit Of Body Work And Chassis Work... hotrod389 Hotrodding Basics 7 05-23-2007 07:12 AM
