a good spray can paint remover... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2018, 08:45 PM
I painted my Nova kick panels about 20 years ago with Black spray can. Now, what's an effective paint remover for this?
Old 03-06-2018, 09:56 PM
Off vinyl? I know of nothing that will work without destroying the vinyl.
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
Lacquer thinner on a rag should wipe it right off.
Old 03-07-2018, 04:36 AM
astroracer's Avatar
Last wiki edit: Crankshaft Coalition Wiki
Right^^^ DON'T soak it. Just clean it off with a damp rag or paper towel.
Mark
Old 03-07-2018, 05:36 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
Jassco has a very good spray can stripper, you can get it at Lowes.
Old 03-07-2018, 06:38 AM
Off vinyl? I know of nothing that will work without destroying the vinyl.Brian
Not sure if it's vinyl or just plastic. It's the hard plastic ones.
Old 03-07-2018, 06:49 AM
I checked and they have quite a few items under that name. Which one? https://www.lowes.com/search?searchTerm=jassco
Old 03-07-2018, 08:41 AM
AirwolfPJ's Avatar
Lacquer thinner as stated and used as stated. There are also enviromental friendly strippers that come in a tub that may work. Also you can try an enamel paint reducer as it's not as "hot" as lacquer thinner.
Old 03-07-2018, 10:11 AM
WHOA THERE! DO NOT use Jassco, I don't think DBM knew they were plastic, DO NOT put a paint stripper on there! Even lacquer thinner will VERY likely damage the plastic.
Why do you need to remove it?
If you use ANYTHING do a test on the back side, but damn with the texture something like that usually has, this is a tough one.
Old 03-07-2018, 11:40 AM
Use Easyoff oven cleaner, it will not harm the vinyl or plastic. I would test the back of the panel just to be sure. I’ve also heard about using Wesley’s (sp?) Blechewhyte,Simply Green and Pinesol. You will need to soak the parts for a while and scrub with a brush any residue that won’t come off.
Old 03-07-2018, 02:36 PM
The original plastic color is blue. I want to restore as close as possible. So something strong melts the plastic?
Old 03-07-2018, 03:18 PM
So, why can't you just spray the blue you want over what is there?
Old 03-07-2018, 03:24 PM
How about brake fluid?
It comes in a plastic bottle......
It takes paint off.....
Old 03-07-2018, 09:07 PM
OK, will try that out. How long does it need to soak?
Paint Remover 57halfton Paint 12 10-13-2015 06:18 AM
Paint Remover fatrat Body - Exterior 2 12-10-2012 05:54 PM
Paint REMOVER Blown 23 T Body - Exterior 5 01-03-2012 05:13 AM
DIY infrared paint remover Jon Hotrodders' Lounge 4 03-24-2006 08:59 PM
paint remover Busted Knuckles Body - Exterior 0 03-11-2004 06:00 AM
