Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - great wiggle wire lever off Ebay
Old 03-23-2019, 09:09 PM
tech69 tech69 is offline
put up or shut up
Originally Posted by 55 Tony View Post
Oh! Ok, do you tack weld it in the dent then it pulls like a stud puller but it's spread out more evenly? When pulling is the flat plate part against the good sheet metal? It seems like it would cause more damage that way so probably not. Do you ever use a slide hammer with it?
you just look for an edge or something tight that will hold it's ground to pull off of. As stated, slide hammering isn't working the metal how it's supposed to be worked out. You're really supposed to be pulling WHILE hammering to release pressure and work highs/lows at the same time. The repairs come out so much better when that's done. Guys who use the hammer and then smack down the lows after the fact are the guys who usually have panels with too much flex or worse with an oil can, but you do what you gotta do sometimes.
