Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ground clearance
  #16 (permalink)
Old 08-16-2019, 07:02 PM
cerial cerial is offline
235 r15 is going to get you lower cost tires. You can run a all season or winter 235 for under $100ea.
The spring rate can be calculated to get close. But it is really a butt test thing, with something that YOU feel is right for your driving style.
Record your current springs. Get the thing moving. Then you can adjust the rate to fit you.
