Ground clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2019, 10:16 AM
Ground clearance
Currently, on my project car, I am running 195/60 x 15 tires. I want to get an additional 2", or close to it as possible, ground clearance. If I put on 235/60 x 15 do you think that would give me the additional clearance I am looking for?
Old 08-16-2019, 11:43 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
According to my tire height calculator your current tires are 24.21" tall, the 235 tires are 26.10". Doing the math you would see approximately 2.89" increase.
https://tiresize.com/calculator/
Semper Fi
Old 08-16-2019, 11:50 AM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
According to the internet, a 195/60-15 tire has a diameter of 24.2 inches and a 235/60-15 tire has a diameter of 26.1 inches. The difference is 1.9 inches on the diameter, but since we are looking for radius, we will divide by 2 and find that the difference between the two tires is 0.95", or roughly 15/16ths of an inch.
68NovaSS made two errors. The first was a subtraction error and the second was failing to use radius instead of diameter.
Old 08-16-2019, 11:51 AM
1.89, correct?
Old 08-16-2019, 11:52 AM
Tire size
That would be, 1.89" taller, correct?
Old 08-16-2019, 11:58 AM
So, would that tire size, 235/60 x 15 give me my approximate 2" more ground clearance I need then?
Old 08-16-2019, 12:00 PM
Wiki Edits: 326
The larger tire will be 1.89" to 1.90" taller standing side by side with each other, depending on the source of the measurements, but it will not raise the car that much, because the measurement from the centerline of the axle to the ground will be the RADIUS of the tire, not the diameter. I say again, you will gain about 0.95", or about 15/16ths of an inch.
Old 08-16-2019, 12:07 PM
Gotcha. So, basically, with the taller tire, I would gain only close to an inch in ground clearance. Wonder what size tire I would need to get a 2" increase
Old 08-16-2019, 12:19 PM
Wiki Edits: 326
You would need a tire that is 4 inches taller on the diameter, standing side by side.....about 28.2 inches. That would make it 2 inches taller on the radius, raising the car by 2 inches. A 285/60-15 should do it, they're 28.5" on the diameter.
Right on Richard, I don't know where my head was at in my math, thanks for the correction.
Old 08-16-2019, 04:23 PM
So then, maybe something like a 225/75 or 235/75 may do the trick. I would have about 5" clearance from bottom of my oil pan to ground. What do you think about that? Enough? Guess I could always add some taller coil overs also
Old 08-16-2019, 04:48 PM
What is the project car?
Thinking drop spindles and sua(flip) with or without a block may get you down 2".
Might not even need to relocate shock mounts.
Old 08-16-2019, 04:56 PM
Thanks. But you know what I was thinking, though, I may need a 225/75 (29.1" diameter) or a 235/75 (28.9" diameter. That way, the 225/75 would be 4.90" taller than my 195/60 and the 235/75 would be 4.70" taller than my 195/60 which would actually make the ride height 2.45" and 2.35" respectively. In my case, that would put the ground clearance, from bottom of engine oil pan to ground at about 5-1/2" to 5-1/4". What do you think about that?
Old 08-16-2019, 04:58 PM
No. I want to raise it 2", not lower it. And, by the way, this is a fiberglass replica of a 1929 Mercedes SSK roadster on a 350 Chevy powered 2"x 3" tube frame
Old 08-16-2019, 05:02 PM
Wiki Edits: 326
In my experience, the absolute minimum is 4" for a street-driven car. I used to keep a 4" by 4" piece of wood, about 16" long, laying over in the corner of the garage. If I had a component that looked like it might be questionable, I'd get under the car to sweep the block of wood under it to see if it cleared and by how much. If the car is close to being done, this works fine, but if the car is just getting started and you have engine, transmission, cooling, exhaust and so forth to go yet, then you might want to give the item in question a little fudge room. You can figure it pretty closely if you know the front and rear spring rates. 350 lbs per inch is common for front springs, so if you have, for instance, 900 lbs of motor, trans, cooling and other items to go yet, then you can divide 900 by 350 and find that those items will lower the front of the car about another 2.57", or about 2 9/16". Divided by two springs, that's about 1 1/4". It's just math, but if you've got 5 1/4 inches of clearance on the pan, you're golden if the car has most of the heavy stuff on it already.
Let's say that you weigh 200 and your passenger weighs 150. That's 350 lbs supported by two 350 lb rate springs and two 200 lb rate springs. Total spring rate is 1100 lbs, so 1100 divided into 350 drops the body 0.318 inches, or a little over 5/16" when you and your passenger get aboard.
Here are some photos for the fellows who are not familiar with this replica car......
https://www.google.com/search?hl=en&...Wj_AV8Q4dUDCAY
Old 08-16-2019, 05:37 PM
thanks for all the info. Now, how do I figure out the rate of my springs that I have? Also, here is a pic of one of the SSK's as a street rod
Name:	Gazelle Hot Rod.jpg
