Harbor Freight transmission jack - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2017, 04:12 PM
Deezil's Avatar
Made a little video of my new tool, pretty useful, I like it!
You Tube
"> You Tube
" type="application/x-shockwave-flash" width="425" height="350">
Old 06-12-2017, 06:36 PM
I know some have good luck with HP jacks. I didn"t. Bought a new
Pittsburg about two years ago and after using it three or four times
(and warranty had gone out) if you jack up a car say to change a
tire and leve it up over night, the next morning it will be on the
ground and it does not leak any fluid. I would say a trans jack
might be different as you will most likely just take the trans in or
out and let it down your self.
I bought two of their battery chargers and they have done well
thus far.
I am that guy who probably bought the 1 dud out of a 100
Old 06-12-2017, 07:55 PM
Dclifton32's Avatar
only problem I had was how high you have to raise the car.
Don
Old 06-13-2017, 09:12 AM
Deezil's Avatar
Don
Yeah, that is the hard part, with a normal car jack I dont know if Id get it high enough. But you can always get the trans onto the ground from this point and slide it out.
Old 06-13-2017, 11:04 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Hyd jacks are not intended to be left overnite. put a jackstand under the car and let the jack down.
Sam
thus far.
Old 06-13-2017, 04:40 PM
Dclifton32's Avatar
That's what I did but it's a little hard to wrestle a th400 up on the lift buy your self.
Don
Old 06-14-2017, 09:43 PM
Last wiki edit: Window removal and installation
Wiki Edits: 11
They sell replacement seals for almost all jacks these days, even the imported ones. They're not easy to find but some websites will have pictures, measurements, and a list of known jacks the seals they offer will fit. The main seal, AKA a "U cup", is usually all you need to fix a sinking jack.
You can do this repair yourself but I had a tough time unscrewing the the cylinder cover, THAT was a bear. The rest was easy. And my stupid imported floor jack works like new again.
Old 06-15-2017, 10:54 AM
Sam
I've got a Walker floor jack and got it in 1968. Have used this jack
many time on hotrods and it would hold one up a week or longer.
About two years ago it went bad, so I spent about $125.00 on parts
and it's new again. I don't think jacks are made like they use to be.
The HP floor jack is still ok to change tires etc, but just don't put a
lot of trust in it. As mentioned before, maybe I just got a dud.
Harbor Freight Jack Problem ssanto Garage - Tools 11 10-14-2016 07:02 PM
Harbor Freight 2 Ton aluminum jack gatliff Garage - Tools 1 03-26-2015 08:43 PM
Harbor Freight Floor Jack???? beertracker Garage - Tools 10 02-05-2012 05:40 PM
Harbor Freight eloc431962 Hotrodders' Lounge 27 11-05-2009 11:13 AM
Harbor Freight fuses jray Electrical 20 10-10-2007 07:33 AM
