Harley davidson carburator support bracket? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2019, 04:48 AM
Wiki Edits: 31
I'm putting a Harley Davidson CV-40 carburetor on my little Suzuki. On a Harley the air cleaner bolts to the breather bolts to hold it in place but there is no clamp on the spigot.
I'm using a 2 bolt spigot carb adapter that uses a clamp. Do I still need to fabricate a holder mount?
Old 01-05-2019, 09:41 AM
I would put an out board bracket/support of some sort on it. There's not alot of meat for a standard hose clamp to hang onto on the backside of a H-D CV. A CV 40 might be a lot of carb for a little Suzuki.
Old 01-05-2019, 11:40 AM
How big of a Suzuki?
Bogie
Old 01-05-2019, 11:53 AM
Wiki Edits: 31
It's my 660cc mini truck. OHC 12v 3cyl. The factory carb is around 38mm but is in need of replacement and the trucks idle control system isn't working.
Old 01-05-2019, 12:37 PM
The Cv40 more then likely came off a 1340. More then likely a 42-44 pilot jet and 160-180 main with an emulsion tube set up for the 1340cc's and how much air it pulls. Kind of seeing a tuning dilemma.
Unless the original is just slam wore out might be worth a cleaning and a few gaskets. Sounds like something is plugged in the idle circuit.
Old 01-05-2019, 12:52 PM
Wiki Edits: 31
I bought one set up for an 883 Sportster. I'm prepared to re jet it as needed.
Old 01-05-2019, 04:44 PM
Wiki Edits: 31
What kind of jetting do you think I might need to start? I was thinking like 175 main, and 35 low jet
Old 01-05-2019, 04:55 PM
Wiki Edits: 31
The original uses 2 vacuum dashpots, 2 relays and 2 vacuum solenoids to control the idle. The throttle lever system rides on one of the 2 dash-pots at all times. Something is causing the entire system to go erratic. It will idle correctly sometimes, and then other times it's racing due to the high idle kicking in, and sometimes it's completely floating because it's not riding on a stop. The relay's alone are near $100 each plus a month to get them.. It is made by Mikuni and I might be able to take off all the extra throttle control stuff If I could find a bracket. But the new carb tuned correctly should work fine. Or at least buy me some time to fix up the original carb/ system
Old 01-06-2019, 08:10 AM
Wiki Edits: 31
I ordered a 170 main jet. It has a 185. I think. It's a knockoff carb so I didn't pay a lot but it does look good. I'll go through it when I swap the jet. The pilot jet, I'll just adjust the mix screw to get it good enough. The engine really likes 3k RPM and up. since it's low geared it runs about 5k rpm at 90 KPH ( ~55 MPH ) and will wind out to about 7k RPM so it can use a little fatter mix, rather than leaner as any mis tuning and I could burn it up
Old 01-06-2019, 03:16 PM
What carb are you using? Usually a bracket from the carb mount stud to the crankcase is all you need.
Old 01-06-2019, 03:57 PM
BuzzLOL's Avatar
Cars, Trucks, Boats
Today's gas can leave an almost invisible waxy build up that blocks fuel flow... that may be what you're dealing with...
Old 01-06-2019, 04:46 PM
Wiki Edits: 31
Harley Davidson/ Keihin ( sp ) CV 40 carb. It's a spigot mount so I have a spigot- bolt on adapter
Old 01-06-2019, 04:57 PM
Wiki Edits: 31
starting cold has a bit of an issue. Takes about 3-4 mins before it will hold an idle from cold, but once it's at idle it's rock solid, until the control system takes over for engine load or temp depending. Slight stumble stabbing throttle if it's cold out but it's carbed. The real issue is with the control system which is a dumb system with no ECU feedback. I worked on it a little today just to try to get the idle to hold solid and figure it out... One dash pot pulls, and the other pushes. But the switching system with vacuum actually allows one to let go and the other to grab. The problem is the pusher is not pulling all the way back causing the throttle lever to float in between the stops. I tried just disconnecting it's vac and plugging it, which wouldn't allow the engine to even start. I'm going to put a heavyish spring on the dashpot to force it to return, and it should be ok for a while. When the system was working correctly you would swear it was fuel injected it ran so smooth
Old 01-07-2019, 03:52 PM
I never did like those carbs. I prefer a Bendix. But I suppose it beats a Mikuni.
Old 01-07-2019, 04:59 PM
Wiki Edits: 31
It should work ok once I have it jetted right.. If I didn't get 39 mpg with the truck, I wouldn't bother keeping it around but it's really too handy and economical to let it go.
Harley Davidson shocks kleen56 Suspension - Brakes - Steering 9 07-21-2011 06:12 AM
Harley-Davidson Factory Tours mgold Hotrodders' Lounge 3 08-25-2009 07:31 PM
Harley Davidson Polish Painter Body - Exterior 6 08-01-2009 10:42 AM
Harley Davidson site as good as this one? zachscc Engine 1 08-26-2003 10:58 PM
I just bashed the baffles outta a 2 day old harley davidson sportster! stonedchihuahua Hotrodders' Lounge 33 07-06-2003 11:49 AM
