Have reddie heater, sluggish fan - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2014, 10:19 AM
bsa_bob2's Avatar
Does anybody have a"parts torpedo" heater setting around?, i am having a time getting a motor for mine.or---someone to repair it . this ones 110.000 BTU. Contact me- thanks for looking ,even if you can't help me bob s
Old 11-19-2014, 07:25 PM
BOBCRMAN@aol.com's Avatar
Many of those heaters use a cheap "mono bearing" motor and can be rescued in most cases by punching or drilling a small hole in the rear cover and adding lube oil. The oil felt gets dry and doesn't lube the shaft properly.
You may have to spin the motor manually to get a start but once the oil gets to the shaft it will spin like a new one.
Old 11-20-2014, 07:54 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
also ,just like a car, theres a filter (screen) in the tank ,if it starts having an uneven flame or sputtering and smoking just clean the screen and it'll run like new again.I have to lube the fan and clean the screen on mine every season..and a new spark plug once in a while....someone threw it out 10 yrs ago and I've been using it ever since...
Old 11-26-2014, 07:58 AM
Wiki Edits: 11
every season my fan squeels when I plug it in so I get my PB blaster and spray it good works fine all winter...
Old 11-26-2014, 08:07 AM
Irelands child's Avatar
Last wiki edit: Ford engine specifications
If a good oiling doesn't work (it probably will), just pull it apart and look for a similar fractional or sub-fractional motor on line. I tried to find the link I used a few years ago, but couldn't spend enough time. That one had virtually hundreds from a couple bucks on up to a lot of those greenbacks
Irelands child
Old 11-26-2014, 12:25 PM
Wiki Edits: 11
I had the cooling fan on my big welder burn up and man they sure were proud of them, they wanted 150 I think ,we had an old fridge at the shop that didnt work that we were using to store parts in so I pulled the cooling motor out of it and fabed (cobbled) it into the welder, its been almost 10 years now and still working great..
delete
Heater Fan bigal69 Hotrodding Basics 1 03-10-2014 01:49 PM
question about old heater fan direction yragat Electrical 16 10-04-2011 10:32 AM
heater fan only blows on low 86Crewcab Electrical 9 11-09-2010 06:30 AM
Heater fan problem grapro Electrical 5 09-03-2008 10:48 PM
heater fan runn141 Electrical 6 01-20-2007 09:02 PM
