having trouble with wrinkles - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 10-23-2018, 02:27 PM
So ive been restoring a 73 nova,ive been having trouble with wrinkles lately,& not just on this job,happened on the last one as well,ive done every step,from prepall,to primer,to sanding,& yet still getting them,ive even left the thing alone for 48 hrs come back lay my clear,& lo & behold,wrinkles,any tips for me???
Old 10-30-2018, 07:26 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Wrinkles? I don't know what that is, can you post
a picture? Sounds like lifting to me but really not sure.
Old 10-30-2018, 06:37 PM
Yes thats what im talking about,lifting,it looks like wrinkles in the paint,ive had it happen in base & clear,even after sanding & repriming the panel.
Old 11-01-2018, 07:11 AM
jcclark's Avatar
The Penny Pincher
Sounds like something is incompatible with each other.
What brand paint are you using for basecoat?
I would first look at what ever you are using to reduce your product,
What do you use to thin, lacquer thinner, reducer?
Are you sure it's good?
I have had some issues like that when putting base on over primer
when putting the first coat on to heavy in cooler weather with
to much reducer.
Old 11-05-2018, 05:54 PM
Thanks,ive been using valspar products,for base,u-pol primer & hardner,i use usc clears,& reduced with a valspar reducer,slower in cold weather,faster in warm,whaddya think???
Old 11-05-2018, 06:49 PM
Not fully understanding. It was painted and for some reason needed to be repainted and now it's lifting or it lifted the first time out? Some clears need some extended cure times before recoating with anything or they will bust up. 48hrs might not be enough some I have used recommend 72 hrs. Overall/multi panel clears are slower and you didn't say if baked. I'm not familliar with the Usc clears or valspar basecoats. Some basecoats are extremely temperamental if they are not cleared within the time window and will wrinkle or it's a straight up compatability issue. Not all reducers are created equally, and you're not putting some wonky basecoat reducer in the clear? Does the usc clear actually call for a reducer? Just asking, throwing stuff out to think about.
Something is not playing well together and you're using products from multiple sources. 2k Primer is usually pretty stable, but it's better to get the sealer, base, clearcoat, and the associated reducers and activators from one label. Mixing and matching sometimes works and sometimes doesn't. Not worth saving a couple bucks to have issues.
Old 11-05-2018, 07:26 PM
Also add, an old previously opened can of activator can really wreak havoc. Anything more then a couple months old can be a problem. Do the wrinkles happen where you break through sanding as would a basecoat without activator?
Old 11-07-2018, 06:51 AM
jcclark's Avatar
The Penny Pincher
That's backwards! You need to slow it down in hot weather and speed it up
in cold weather.
Old 11-07-2018, 02:44 PM
Ur right i did have it backwards my bad,& the cars im talking about were previously painted,but not anytime near to when i re-shot them,& no i didnt bake them,just starting out with my own shop,& havent made that kind of money yet to b able to have all the fancy stuffs,but my shop is fairly warm i do have a heater,i know its not the same as an oven,but it keeps it warm,as far as compatibility goes the paint store i use,assures me that all my products are compatible.
Old 11-07-2018, 05:15 PM
Some store clerks have been painters and some haven't so him assuring you doesn't mean a whole lot and he doesn't have to deal with the mess and surely won't cover any materials on the screw ups. Activators have a shelf life even unopened and paint stores have a habit of pushing dead materials to get them off the shelf for fresh product the same as ebay. Even the big name paint companies have been known to put out a bad batch requiring you to toss the stuff and get fresh.
Having trouble with weld penetration teched General Rodding Tech 8 03-01-2005 10:05 AM
Having trouble pumping up 305 lifters 87442lover Engine 7 07-13-2004 07:23 PM
Having Trouble 67stangbo Engine 0 09-18-2003 02:44 PM
I need some body parts and am having trouble . building another one Body - Exterior 1 08-29-2003 07:37 AM
Having trouble finding parts bonuts Body - Exterior 6 04-12-2003 05:56 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
