Head gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2019, 04:59 PM
Head gasket
I have a head gasket that doesn’t quite want to fit over the dowels. Would it be okay if I enlarged the dowel holes slightly on the gasket to make it fit ? The holes on the gasket are somewhat triangular.
Old 02-17-2019, 05:10 PM
ericnova72's Avatar
More for Less Racer
Just push it on, the gasket will stretch a tiny bit around the hole...this is a normal thing. Just about all head gaskets are like this, one hole round and one hole triangular, this allows for flexibility to fit the tolerance on location of the dowel pins.
The Following User Says Thank You to ericnova72 For This Useful Post:
loafing1 (02-17-2019)
Should I use a gasket sealer on a .015 shim head gasket? Caprice Sleeper Engine 2 08-23-2012 07:46 AM
Head gasket thickness, Gasket or Shim? rollie715 Engine 6 04-25-2012 03:15 PM
cracked head or head gasket???? onebadmerc Engine 12 12-04-2008 12:10 PM
Mr Gasket Ultraseal Head Gasket's 406 ss monte Engine 4 05-03-2008 08:19 PM
oil on head bolts and head gasket bullheimer Engine 7 05-25-2004 04:50 PM
