header gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2019, 09:11 PM
header gaskets
Been over thirty years..so have to ask. Do header gaskets go on dry now. If I remember, we used to spray them with something. Is that still the norm? If so, what is used?
Old 09-07-2019, 07:43 AM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
I think that was a copper spray. However if the surfaces are flat, the gasket will seal fine, bolts need to be secured evenly.
To much goop unnecessarily used ...... IMO
Pep
Old 09-07-2019, 08:22 AM
Old(s) Fart
Last wiki edit: Wheelbase database
Having tried just about everything on the market, I can say that the best available today are Remflex. Just pay attention to the bolt torque - overtorquing will crush the gasket and mess it up.
Old 09-07-2019, 08:29 AM
silver74vette's Avatar
I agree with Joe, Remflex are working great for me. I torqued them in three steps which may have been overkill and used locking header bolts. I have an old set of hookers that tended to blow out other gaskets.
Old 09-07-2019, 09:51 AM
Just use Remflex, or all metal copper, or alumunim gaskets.
Makes life simpler for a few addirioal dollars.
Bogie
Old 09-07-2019, 11:26 AM
johnsongrass1's Avatar
Race it, Don't rice it!
I use the factory type perfected metal and think of any particular time they failed.
Old 09-08-2019, 07:04 AM
jaw22w's Avatar
I quit using header gaskets. I bought a set of Sanderson headers for the roadster. The instructions said not to use a gasket. Instead put a 1/8" bead of high temp red silicone around the ports on the head and let it sit overnight and cure. Then install the headers. It worked great on the roadster.
I had built a set of headers for the model t coupe and always had trouble getting them to not leak with gaskets. So I tried the Sanderson method. After putting the 1/8" bead on the heads and letting it cure, I put a very thin coating of silicone on the header flanges and installed the headers, I finally had sealed headers.
It's a lot cheaper than gaskets. You might give it a try.
Old 09-11-2019, 07:14 PM
55_327's Avatar
I have been using Fel Pro gaskets with a steel core for 20+ years now. Never had a leak with any of them. Nor have I had a header bolt come loose.
For a small block Chevy with stock port sizes, P/N #1444 is ingrained in my brain!
Old 09-11-2019, 09:48 PM
rip-tide's Avatar
55s & 327 were a popular build in high school, and the 301.
Same here, my favorite header gasket set, a metal and gasket sandwich.
Good seal never had a header bolt back out. Prefer allens, for a cleaner machine appearance
Pep
ID:	447543   Click image for larger version
Old 09-12-2019, 04:14 AM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
With this Fel-Pro stuff, I've never had a leak or replaced one....
https://www.jegs.com/i/Fel-Pro/375/2499/10002/-1
Crank the bolts home. Never come loose either.
ID:	447549   Click image for larger version
Old 09-12-2019, 04:28 PM
55_327's Avatar
That's a good way to describe them!
