Header Reducer Gasket... Copper? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-04-2019, 05:49 AM
Tim C's Avatar
Originally Posted by 55 Tony View Post
The ultra copper RTV has been working well, thanks!
That's great. I use it on all my header gaskets with great success. Like I said, if you have to pull the exhaust for any reason, just scrape off the old rtv, put some fresh on the old aluminum gasket and bolt it back up. I've done it plenty of times.
  #17 (permalink)
Old 07-04-2019, 06:55 AM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
The only sure cure, would be to true the mating surface.
What are these ball and socket type, got a link ?
Curious
Pep
  #18 (permalink)
Old 07-04-2019, 10:15 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Curious
Pep
OEM's have been using them for 1000 years
  #19 (permalink)
Old 07-04-2019, 10:49 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Like with the old doughnut gasket, right?
Semper Fi
  #20 (permalink)
Old 07-04-2019, 02:35 PM
Excellenceautosoluti's Avatar
Curious
Pep
https://www.jegs.com/i/Hedman/500/21...xoCdYgQAvD_BwE
I paid almost $100 for these just few years ago. Price has come down quite a bit since then....
  #21 (permalink)
Old 07-04-2019, 04:30 PM
rip-tide's Avatar
Ok, must have misread and missed flange in the discussion ... that is a good fix, not seen it before.... Solid !
Maybe 100 bucks, however you're still running em an they are not leaking ......... $$ well spent
Thanks,
Pep
  #22 (permalink)
Old 07-04-2019, 04:38 PM
rip-tide's Avatar
Thousand years ! d a m cars have been around a lot longer than I thought.......
But those are 2.5" a wee bit small for what Tony is trying to cure.
Pep
  #23 (permalink)
Old 07-07-2019, 07:26 AM
predator carb guru's Avatar
Mark Goulette
I run dead soft aluminum header gaskets on my dragster...They work well. Conformed better than copper gaskets did since they are somewhat softer. Both work very well. Ultra copper also works very well as long as the surfaces are nice and flat. Get a gap and it will blow out eventually. I do prefer copper collector gaskets as they seem to hold up to pretty much anything and last forever. Coating them won't hurt either, may actually help a bit when the surfaces aren't flat.......
Pretty much stopped using fiber style gaskets on anything high performance. Much better options out there for sealing these days...
More header gasket stuff 62restomod Engine 4 04-30-2012 09:18 PM
Fabricate thick Header adaptor flange gasket 001mustang Engine 9 05-22-2009 11:25 PM
Double gasket to stop header leak? joefromcocomo Engine 8 05-05-2005 07:04 PM
header to pipe gasket. uniques67 Engine 1 06-21-2003 12:03 AM
header gasket major help needed Crazy d Engine 2 06-20-2003 09:13 PM
