Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Heads Or Bore?
Thread: Heads Or Bore?
Old 09-25-2003, 04:10 PM
Robinson Robin Robinson Robin is offline
the amount of horse power you would gain from boring would be negligible. by making the cylinder walls thiner you are allowing more flex which creates more blow by. As for heads there are power gains to be had a lower rpm with the right heads but choose carefully.
