Heater fan problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2008, 01:36 PM
grapro's Avatar
Last journal entry: winter
Heater fan problem
I have a 1999 chev pickp and the heater fan only works in high, checked under the hood for relays but couldn't find anything, Any ideas on what is going on?
Old 09-02-2008, 02:18 PM
T-bucket23's Avatar
Last wiki edit: Engine basic condition - how to check
Wiki Edits: 26
There is a fan control module, some are made up of resistors and some are completly electronic. Either way it is most likely your problem. Some vehicle recently have also had a problem with the harness melting near the switch. I think that was Fords mostly.
The unit is usually located near the fan motor and will generally have 5 or 6 wires attached to it. The reason high works is it usually bypasses the module.
Chet
Old 09-02-2008, 02:20 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
First off check the fuse #12 25AMP in the inside fuse box.
The high blower relay is located on the front top of the blower housing, behind the glove box.
There is also a blower resistor on top of the blower housing.
The blower high speed relay get's it power from the blower fuse 50AMP in the main fuse box under the hood.
The #12 25AMP fuse supplies the blower control module with 2 power leads.
Hope this helps.
Old 09-02-2008, 04:12 PM
302 Z28's Avatar
In addition to what has been said, there is a fan wiring plug above the glove box that is known to melt, check that.
Vince
Old 09-02-2008, 04:17 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
on a much older truck/car, there is the resistor installed in a duct (near the heater box under the dash) to keep it cool. If the multi-wire plug gets knocked off, then it only has high. No idea what a '99 would have
Old 09-03-2008, 10:48 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
A buddy of mine had the same problem with a Blazer about that vintage. On the same module that contains the coiled resistor wires for the lower speeds there are also high temperature switches designed to go open circuit if things get too hot. One of these had failed open circuit, leaving him only with high speed.
I bypassed the failed thermal switch (somewhat bullet-shaped) by soldering in a jumper wire - worked fine afterwards.
This is the module that lives in the heater box, accessible from under the hood and near the blower motor.
Good luck. It sure is annoying to only have one speed!
blower idle rpm problem Ratoflic Engine 7 12-01-2008 04:31 AM
electric fan relay problem ron2424 Electrical 6 02-25-2007 11:12 AM
heater fan runn141 Electrical 6 01-20-2007 09:02 PM
Correct size & type of radiator fan & clutch? Steve S Engine 3 12-04-2006 11:29 AM
85 Olds to Chev fan shroud problem oldsmo Engine 4 03-26-2006 09:45 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
