Heater - sucking air from outside? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2011, 02:49 PM
staleg's Avatar
Last journal entry: Hand brake
I have a question for you guys that have a heater in your hot rods:
Does it suck air from outside of the car, or does it just heats up the air that's in the car?
First alternative is maybe more efficient in wet weather? Last alternative is for sure much more simple to make...
Old 02-07-2011, 03:26 PM
Generally speaking, the heater uses outside air. I have seen some cars and trucks that you could choose either outside or inside air.
Do you just want heat, or is the heater going to do some defogging of the windshield? If you use inside air for this, after a few cycles through the heater, the air would be saturated with humidity and would not be very good at removing mist from the inside of the windshield.
Old 02-07-2011, 03:55 PM
Joe G's Avatar
Aftermarket Heat & A/C systems such as Vintage Air do not breathe outside air. It's one of the compromises that allows these systems to be so small. If they were to breathe outside air, the A/C evaporator coil and condenser (and maybe the heater core) would have to be much larger.
Hope this helps.....
Old 02-08-2011, 04:55 AM
staleg's Avatar
Thank you for your answers!
I will make the heater able to suck outside air then. Seems like it will be worth the small amount of extra work.
And the air intake will not be visible outside the car.
Pictures will come later.
Old 02-08-2011, 08:42 AM
1ownerT's Avatar
Home School Valedictorian
Wiki Edits: 4
Just drawing outside air will not stop the humidity issue, the outside air can be as humid as the inside air. OE systems use the air conditioner to remove the humidity on the defrost setting.
Old 02-08-2011, 09:10 AM
Living in Norway, I am going to guess that the car you are putting th heater in is not a convertible.
Cars are set up to draw outside air in because it helps prevent engine exhaust from getting in the car.
I find it ironic that somebody whose last Wiki edit was about health and safety in the garage is not concerned about your health and safety when you are driving your car.
Old 02-08-2011, 09:15 AM
NEW INTERIORS's Avatar
life is a temporary assignment
I like when it suck's the inside air myself.. Like the way Vintage Air is set up..
Old 02-08-2011, 10:08 AM
staleg's Avatar
No, not completely, but it will probably do the job better than drawing only inside air.
Inside air is usually way more humid than outside air even in rain, because the drivers/passenger clothes are more or less wet. And add that to the drivers/passengers breath. Put he heater in your daily driver on "recirckling air" in rainy weather and see for yourself.
AC is not an option.
I live in Norway, yes, but the car is a Roadster (a 34 Ford).
I'm planning to make some sort of Carson top for it later, and then the heater will be nice to have in wet and/or cold weather.
I have also changed the top of the doors to accept glass power windows.
Old 02-08-2011, 10:55 AM
1ownerT's Avatar
Wiki Edits: 4
W. T. F. are you referring to? You do realize that there are recirculate options on OE systems...allows one to recirculate the interior air.
Old 02-08-2011, 10:58 AM
1ownerT's Avatar
Wiki Edits: 4
Put your OE system on defrost and watch the ac compressor engage.
anyone have problems sucking oil pan dry willis 77 Engine 14 08-09-2010 06:08 AM
Sucking My Oil Pan Dry goingonmotor4 Engine 11 08-23-2009 12:23 PM
GMPP 454 sucking oil Bryan59EC Engine 14 08-31-2007 05:02 PM
sucking noise Super Chevy Engine 6 11-29-2004 11:01 PM
valves sucking oil wrenchturner Engine 3 05-27-2002 05:42 PM
