HEI questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2016, 03:27 PM
HEI questions
Have an HEI in my 74 Nova with 350. I purchased the car with this distributor in it. Have the updated control module, new cap and rotor and stator wires are fine. I don't know for sure about the coil. When I set plug gap at 35 it runs good with a mild or slight miss. When I open the plug gap to 45 it misses even more. Any ideas?
Old 07-12-2016, 04:29 PM
Greg T's Avatar
Music and Hot Rods
Sounds like wires may not be fine. Fire it up in the dark and see if you can detect any arcing around the plug boots or the cap. Also possible weak coil unable to fire enough juice to bridge the gap.
Old 07-12-2016, 05:06 PM
BuzzLOL's Avatar
Cars, Trucks, Boats
When does it miss? Idle? cruising? accelerating? WOT?
Did it ever run without a miss?
Crank engine while looking at spark color on a spare spark plug. Is the spark mostly white color? yellow? blue? Should be mostly a fat blue color... Whether .025" gap or .060" gap...
Fueling system could also be a problem.
Old 07-12-2016, 05:12 PM
RWENUTS's Avatar
Do you have a dedicated 12v power supply to the hei?
74 would of had points originally with a resistance wire to the coil.
The Following User Says Thank You to RWENUTS For This Useful Post:
LATECH (07-12-2016)
Old 07-12-2016, 05:21 PM
BuzzLOL's Avatar
Cars, Trucks, Boats
Good point, '74-'75 the changeover period from points to HEI...
Look for 12-14 volts at the B+ power feed with the engine running...
Old 07-12-2016, 05:26 PM
Misses at idle, cruising, or WOT. Can't tell for sure if spark is blue. Edelbrock 600 CFM carb. All I do know for sure is it misses worse when gapped at 45. Tried two sets of plug wires and is exactly the same. Thanks
Old 07-12-2016, 05:27 PM
Also have a fat 12 Gage wire from ignition on fuse block to distributor.
Old 07-12-2016, 05:44 PM
BuzzLOL's Avatar
Cars, Trucks, Boats
Eddy carb.s can't take more than 5 psi fuel pressure without flooding over...
Stock carb.s and Holley carb.s take 7 psi... Stock fuel pumps supply about 6 psi...
Old 07-12-2016, 06:32 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Originally Posted by rwenuts View Post
do you have a dedicated 12v power supply to the hei?
this ^^^^^^^^^^^^^^^^^^^
Fact is stranger than Fiction
HEI re-install questions SUX 2BU Engine 4 04-14-2012 05:02 PM
HEI Questions jim Dunkin Electrical 2 12-24-2011 12:25 PM
HEI questions... GUNTHER19820 Engine 22 08-19-2011 04:02 PM
HEI Questions Jeepdude Engine 1 10-31-2009 12:53 AM
HEI Advance questions 1982 SS Electrical 2 06-30-2005 09:58 PM
