Help with 454 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2014, 09:29 PM
Help with 454 build
I really need help. I'm trying to build a 454 engine for my 79 Camaro. The crank in the 454 is bad so i have to replace it but wanted to add a better cam and things like that while i had it apart. I've never built a engine before so all this is new to me. Any suggestions would be really helpful. i'm trying to keep it on the low end on money but will do something if its going to make a big impact. I know right now i want to replace crank, cam, lifter rods, valve's and rocker arms and maybe pistons. Engine isn't going to be bored either Casting number is 361959 and VIN T0629TST. I'm have 781 heads for it but valves need replaced. Again any help cause i'm lost.
Old 01-31-2014, 11:42 PM
vinniekq2's Avatar
How do you know the block wont get bored?
How should the new engine perform?
Old 01-31-2014, 11:51 PM
Im not going to bore the engine right now. I just want the engine to be around 400hp.
Old 01-31-2014, 11:57 PM
vinniekq2's Avatar
Put a used crank in it.headers.intake.850.match cam to compression ratio
Old 02-01-2014, 12:10 AM
Thats where im getting lost how do I get the compression ratio? I probably sound like an idiot but I dont want to mess something up. Im still learning
Old 02-01-2014, 04:38 PM
BOBCRMAN@aol.com's Avatar
IF the block has decent bores. Order up some mid-dome hyper-eutectic pistons. Keith Black or Sealed Power/Fed Mogul. These will get you just under 10-1 compression. If you are stuck with a hyd cam. Try for something with 225-230 duration @ .050, 112 or so advertised centerline with as much lift as available. Big blocks like lift.. Staying below 230 duation lets you keep a stock or mild t-convertor and decent idle quality. Check Howards cam stuff.
Heads, properly done will cost come $$$$$. 781-049 castings are good . But, stock they have very short v-springs and the exhaust rotators have to be tossed and spacers installed. You will need valve springs with 110-120 seat pressure. Correct aftermkt +.100 retainers and proper locks to get correct pressures, again Howards has the best/right priced stuff
Stainless valves.. No stocker stuff, BBC are famous for dropping stock valves at high speed.
Guides shortened and cut for seals.
Ask around for a machine shop that knows how to do this stuff, many have no clue..
454, bbc, big block, engine build
1954 Caddy To Build or not to Build (with a 454 big block) ditchdoc220 General Rodding Tech 6 01-10-2013 04:32 PM
454 build up Horsepoweraddiction Hotrodding Basics 56 11-22-2012 07:47 AM
454 build up ekacpuc Engine 23 04-29-2010 11:14 AM
454 2bolt 289 block or 4bolt 454 1 piece seal to build a 496 heathj1 Engine 2 12-21-2008 10:22 AM
454 Build roreydo Engine 2 09-01-2003 10:51 PM
