Help identifying rack and pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2018, 09:56 AM
I have a 51 Ford F1 , was told when I bought it, it has a Crown Vic front end. Changing front brake pads matched with a 91 explorer. Rack and pinion is busted need a rebuilt one. No rack that I've seen on a Crown Vic matches my rack. Order the Explorer rack.The Explorer looks exactly like it except for the gearbox,it is slanted forward, will not work. Mine is basically straight up with a slight slant to the driver side fender. Looked all over the rack for a part number, no luck. Hoping to get lucky and someone can look at the pictures and point me in the right direction.
ID:	435973   Click image for larger version
Old 10-03-2018, 10:22 AM
Bob37pont's Avatar
Curmudgeon at Large
Sure looks a lot like this: https://www.speedwaymotors.com/New-T...ers,98778.html
Check the tie rod length and the mounting hole distance. Center to center on this is 15.5", my Mustang II rack was 16", they have offset bushings to allow it to mount. Note that steering is 2.5 turns lock to lock. Good luck!
Old 10-03-2018, 11:42 AM
Mount holes are way off. Thanks for your reply. looked good except for that.
Old 10-03-2018, 03:43 PM
ericnova72's Avatar
More for Less Racer
Check maybe 1998-up Ranger, the ones with Independent Front Suspension 2WD (not the earlier Twin I-beam stuff).
Could be more helpful if you took the pictures on cement or paved surface so detail is more apparent, with a tape measure defining the mounting points and inner tie rod span.
Old 10-03-2018, 04:16 PM
will do tomorrow . Thanks already checked ranger don't think that's it. Found a Aerostar that looks like a winner waiting for seller to send dimensions.
Need Help Identifying Brand / Ring & Pinion HotRodRick Transmission - Rearend 5 05-01-2017 05:59 PM
how to get disc brakes and rack and pinion steering on a 63 fairlane walex Suspension - Brakes - Steering 1 03-03-2012 08:33 AM
Mustang II rack and pinion, pinion Jim H Suspension - Brakes - Steering 3 02-23-2012 11:58 AM
50 ford rack and pinion help jake100 Suspension - Brakes - Steering 2 03-05-2006 06:40 PM
rack and pinion filbee Suspension - Brakes - Steering 6 06-26-2005 10:17 PM
