help me to mountig carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2015, 04:50 PM
Husein-p's Avatar
hi
my engine is chevy 250 L6
my carb is holley 570cfm avenger ...
my intake is offenhauser
now help me to mount this carb in true position on intake manifold !!!
my and friend type is :
http://img.overpic.net/images/y/9/d/...cqbepdcf2p.png
and :
My :
http://i.ytimg.com/vi/egbEy8k2BSs/hqdefault.jpg
Friend :
http://i23.photobucket.com/albums/b3...s/100_0197.jpg
which is true and best ?
Old 03-31-2015, 07:13 PM
RWENUTS's Avatar
You got 3 choices if you want to set your carb with the float bowl to the front.
1. Get a clifford intake which turns the carb to the front.
2. Weld up the holes in the carb base plate that bolts to the intake and drill and countersink new holes.
3. Find a chunk of aluminum and make a base plate that bolts on to the intake and puts your carb in the direction you want.
For better fuel distribution your Offy intake is best. Puts your primaries directly in the middle. Hooking up your throttle can be a challenge depending on if you use a cable or a rod.
The Following User Says Thank You to RWENUTS For This Useful Post:
Husein-p (04-01-2015)
Old 03-31-2015, 08:42 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Originally Posted by Husein-p View Post
hi
and :
My :
Friend :
Your friend is correct. Been there, done that.
The Following User Says Thank You to techinspector1 For This Useful Post:
Old 04-01-2015, 12:12 AM
Husein-p's Avatar
so i'll do this type .
tnx
Old 04-01-2015, 02:56 AM
BuzzLOL's Avatar
Cars, Trucks, Boats
. GM did it your friend's way on the stock Pontiac OHC 6 Sprint engine... but other's did it your way because it was easier for one reason or another and it worked OK...
The Following User Says Thank You to BuzzLOL For This Useful Post:
Old 04-01-2015, 05:10 AM
Husein-p's Avatar
tnq
my way have a positive point !
this is cable installing on carb whit my way cable ( throttle and TV ) installing is very easy but my friend way installing cable is hard !
just this
Old 04-01-2015, 07:47 AM
Old(s) Fart
Last wiki edit: Wheelbase database
Time for a little common sense. The flow paths from the carb venturies to the cylinders are more even with the carb oriented "across" instead of "front-to-back". That's why the intake is designed that way.
The Following 3 Users Say Thank You to joe_padavano For This Useful Post:
Husein-p (04-01-2015), LATECH (04-01-2015), techinspector1 (04-01-2015)
Old 04-01-2015, 10:42 AM
Husein-p's Avatar
tnq
my friend say to me ( him reason ):
1 and 2 bbl of primary in this mode :
engine
3 4
1 2
is good and best mode for fueling because 1-2 primary of the carb seating in center of intake and engine and Fueling to the left and right sides are equal.
but in this mode :
1 3
2 4
front of engine is closer to the carb and rear of engine is Farther to the carb !!! and center cylinders is very close to the carb !
in this mode :
3 4
1 2
center cylinders is A little farther to the primary bbl of the carb and fueling to the both sides and center is very good ...
Old 04-01-2015, 10:51 AM
Wiki Edits: 326
Right on the money Joe, it's all about mixture distribution.
The Following 2 Users Say Thank You to techinspector1 For This Useful Post:
Husein-p (04-01-2015), RWENUTS (04-01-2015)
Old 04-01-2015, 10:57 AM
RWENUTS's Avatar
tnq
engine
3 4
1 2
but in this mode :
1 3
2 4
in this mode :
3 4
1 2
None of your choices are good.
While your last mode would work, it makes it hard to hook up your throttle and tv cable as the valve cover is in the way.
However rotating the carb so 1 and 2 are closer to the valve cover makes it easier to hook up your cables.
Old 04-01-2015, 11:17 AM
Husein-p's Avatar
yeah but i test it if is hard i do this mode .
tnq
Old 04-01-2015, 11:32 AM
RWENUTS's Avatar
Here's a little read for you.
See how others have done it.
Tricked-out Chevy six cylinder engines - The 1947 - Present Chevrolet & GMC Truck Message Board Network
what size barry grant carb is it,been told its an old claw carb,1 3/4 vent Thomas Gravel Engine 8 07-27-2014 01:24 AM
350 carb question demon carb to much? Studedean Engine 5 04-22-2012 12:44 PM
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 12:13 AM
Quadrajet Carb rebuild....parts interchange with another junk carb? Warrant Engine 1 07-31-2006 10:31 PM
Any problems spraying carb cleaner in my carb while its on the motor? batman09 Engine 11 11-29-2005 07:49 AM
