Hinged window - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2014, 08:44 PM
Hinged window
I have a '62 Ranchero that I have been flipping around ideas on my rear window. There is not a rear slider made to fit. And opinions are one would not look good. So is it possible , how hard or crazy would it be to drill the window for hinges like some van and suv windows. Thanks Ken.
Old 02-13-2014, 11:44 PM
I owned one of those Rancheros, I personally can't imagine a need for this in anyway. First off, you can't drill holes in that glass, it's tempered and would literally explode. So you would have to get different glass. If I HAD to have that window open I would make it a roll down. It would take a bunch of work but really not that hard to pull off. cut out the pinch weld, put in a channel along the sides with a slot along the bottom and make a regulator mount to hold a sheet of glass to go up and down in the channel. You would have to have the glass cut as it would need to be taller than the original. Flat glass could be used even though I don't think the original is perfectly flat.
Btu then again I would have to ask, why?
The Following User Says Thank You to MARTINSR For This Useful Post:
papawfalcon (02-14-2014)
Old 02-14-2014, 01:10 AM
I agree with Brian. The simplest way would be to make the window roll down, and there are thousands of station wagons that could provide the pieces to get you started
If you really want a sliding window, take a good look around at the nearest RV dealer
The Following User Says Thank You to Dragonoake For This Useful Post:
Old 02-14-2014, 03:39 AM
I was just thinking of more ventilation in the summer. Maybe a salvage yard rear air and heat out of a van would be easier. Thanks for advice on the window.
Old 02-14-2014, 09:13 AM
Why don't you just install A/C?
BB
The Following User Says Thank You to boothboy For This Useful Post:
papawfalcon (02-15-2014)
Old 02-15-2014, 09:31 AM
That would be a crazy huge piece of glass to put on hinges, and it will NEVER-EVER seal tight enough to be quiet. It will leak.
The Following User Says Thank You to Mitchman For This Useful Post:
Old 02-15-2014, 01:34 PM
That wouldn't be an issue, there are many cars out there with huge pieces of glass on hinges, look at a 90's Camaro! The big problem is the glass is tempered, that and it's just a bad idea on many levels.
Old 02-15-2014, 02:12 PM
The only reason for I was not going for air is just because of the money. $800-$1000. I read an article a while back where guys were putting an air/heat unit out of a van( the rear air/heat small ones). Beings it is a Ranchero I want seating for three and a under dash would stop that (I have a bench seat).
Old 02-15-2014, 02:55 PM
Seems to me the 80's GM wagons did, too
Old 02-15-2014, 02:58 PM
If ... and this is a big if ... It will fit under the seat, it sounds like a plan
1931 chevy 5 window coupe window gaskets yellowbeard Body - Exterior 1 07-25-2013 07:56 AM
1963 split window corvette window moulding removal spacytracy Body - Exterior 0 07-15-2013 11:03 PM
side hinged tailgate 71corvette Body - Exterior 2 08-25-2008 05:02 AM
Hinged Windshield 35WINDOW Body - Exterior 7 02-11-2006 09:08 AM
Converting G-20 Sliding Door to #2 Hinged? Stick'n It Body - Exterior 0 07-12-2004 12:56 PM
