Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley 4160 primary jets
Old 04-01-2015, 09:53 PM
Husein-p's Avatar
Husein-p Husein-p is offline
Originally Posted by TommyK View Post
Do not make any changes until you bolt it on and try it.
right
you first install the carb on your engine and run engine to 50km then check your spark plug : if light your jetting is small if dark your jetting is high and if light with brown your jetting is correct .
before mounting carb in your engine do not change any things .
Certainly for tuning and testing the carb use vacuum geage not your ears !!!
Originally Posted by Buick b4 View Post
Thanks Tommy!
I have a Edelbrock 500cfm too,not sure which is better !!!
holley is better .
where are you ( city )? call me i'm in iran and can help u my friend .
