Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley billet fuel pressure regulator issue.
Old 05-13-2019, 07:53 PM
55 Tony's Avatar
55 Tony 55 Tony is offline
Let me add that if the Carter pump says max 9 psi, all that means is it should never go over 9 psi. It in no way means that with no fuel flow it will reach 9 psi. You would need to know the low psi specs from them to find out the lowest it might put out.
Young enough to learn ... too old to remember.
