Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley Street Avenger 770 - stall issues
Old 08-01-2012, 07:44 AM
Ripper 410 Ripper 410 is offline
sounds like you need to set the air fuel and sync the squirters these are never acurately set on the out of the box holleys however they are usually close you still need to jet and change the squirters according to application if your timing is set correctly you should be able to run without the vac. adv. I set my base at 8-10 deg and full adv. I degree in at 28 for a full swing before 2500 rpms at 36-38 deg. I do not run vac pod after I do this for the simple reason it advances the timing even higher and takes it even farther out of the power curb. however people will argue about timing this is how I do it .Until you get your timing straight you will not be able to correctly adjust any carb. Holley carbs are very tempermental when it comes to fine tuning in this aspect if the timing valve adjustment plug heatrange are not correct it will effect the carb.
