Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley Street Avenger 770 - stall issues
Old 08-02-2012, 08:50 AM
Ripper 410 Ripper 410 is offline
at full manifold vacuum the distributor pod will advance the timing to full swing so disconnect all the vacuum lines and cap them until you adjust everything too where the motor idles and revs properly from the throttle lever then start connecting the vacuum lines one at a time if you are gonna run the vacuum pod there should be a vacuum port located on your front metering plate located about 1/2 of an inch from the top of the carb this is a metered vacuum port this is where you want to connect the vacuum pod that way the pod will only advance under wide open throttle
