Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley Street Avenger 770 - stall issues
Old 08-03-2012, 07:56 PM
Ripper 410 Ripper 410 is offline
factory set the "base" at 10 degrees up too + or - 4 degrees won't really do much as far as performance other than maybe cause a hard or easy start problem other than harm the starter until you get into higher rpms the factory chose 10 deg as base for optimal street operation cause it gave a good range of starter life and gave optimal idle and optimal vacuum 2 deg more will make it a little easier to start but you could lose a hg of vacuum which really won't effect much
