holley troulble shooting - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2005, 08:20 AM
blazin47's Avatar
Blazin Low
I have a couple of 450 holleys on my engine and the accelerator pump will not squirt on the primary carb unless I open the throttle up almost half way. I tried to adjust the linkage on the pump, but that didn't help. The carb was rebuilt, so the acc pump is fairly new. The thing creates a dead spot. Any suggestions
Old 12-29-2005, 09:47 AM
What color pump cams do you have in them and what position are they in?
Old 12-29-2005, 04:01 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
The Knowlegde Base has the info & sites that you need.
Luv the smell of NITRO in the morning.
Old 12-30-2005, 07:09 AM
blazin47's Avatar
Blazin Low
That's most likely part of the problem, I'm not sure what your talking about. If your talking about the pump arm, it's black, position,??????
Old 12-30-2005, 07:31 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Attached to the throttle linkage near the throttle shaft is a plastic pump cam that the pump arm rides on. So when you open the throttle the cam turns and pushes on the pump arm lever. Holley has eight different pump cams to tailor to individual needs. They are distinguished by color. There are two screw holes in the pump cam. The screw can be reached easily. It's just one screw. These are the "positions". Try playing with moving the pump cam in the other positions and see what happens. You are trying to get the pump action to occur right off the idle position. leave a few thousandths of space under the arm adjustment so the pump doesn't trickle fuel under vibration.
Old 12-30-2005, 07:40 AM
These are the various pump cams. You can install them in one of two positions by using the appropriately numbered hole on the cam. For each 10 strokes of the pump they will provide the following amount of fuel:
cam color #1 #2
white 17cc - 19.5cc
blue 18cc - 20cc
red 18.5cc - 20cc
orange 19cc - 24.5cc
black 19cc - 18cc
green 24cc - 30cc
pink 30cc - 37.5cc
brown 36cc
Old 12-30-2005, 08:24 AM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
Does the cam push the accel pump arm immediately? the clearance is set correctly?
If so just make sure the diaphram is still good, no passages are blocked by gasket and the check valve is not sticking.
Old 12-30-2005, 03:10 PM
blazin47's Avatar
Blazin Low
It has a white cam, and the pump arm does move when throttle is pushed. Would a low fuel level cause the problem, because the motor sit's up on a higher than normal angle. I had to lower the primary float level to keep the fuel from filling the secondary bowl VIA the bowl tube because of the angle.
That lousy Holley carb cool rockin daddy Engine 30 02-29-2008 02:01 PM
edelbrock vs. holley carb Super Chevy Engine 43 01-21-2006 09:55 PM
Holley throttle body Kevin45 Engine 1 06-10-2005 11:46 AM
Carb comparison Demon vs Holley DTL504 Engine 12 12-29-2004 02:53 PM
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 02:16 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
