homemade mini chop saw - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-02-2008, 02:40 PM
Well done cboy and a great idea.
I noticed it's mounted on what looks like wood. That's the end for me because I can't make anything out of wood. In grade school (Yes Paris, that was in the middle of the last century.) we had to make a bird house out of wood. Mine looked a lot like a Salvador Daly impressionistic serving tray.
I like metal. I tell my wood working pals that when I order 4130 and aluminum, at least I know there aren't going to be any knots in it.
Ooops, off subject there.....sorry.
  #17 (permalink)
Old 02-02-2008, 04:59 PM
cboy's Avatar
Last journal entry: Finished
Hey, it you can make it out of metal or aluminum it would probably be ten times better. I just used wood (actually cheapo shelving material) because it was there.
Always learning...and sharing what I've learned.
  #18 (permalink)
Old 02-02-2008, 05:27 PM
powerrodsmike's Avatar
Wiki Edits: 161
Natural and organic billet cellulose motorcycle....
Kisses, Mikey
BE different....ACT normal.
  #19 (permalink)
Old 02-02-2008, 05:49 PM
Last wiki edit: How to title a hot rod
Mikey....What are you doing posting that here It has no front brakes .
Shane
  #20 (permalink)
Old 02-02-2008, 06:39 PM
Wiki Edits: 161
It's a baby drum..
The forum won't let me link to a picture.
http://www.pashnit.com/forum/showthread.php?t=40
See the little nublet of a brake handle on the twisty grip side?
I'd never post anything unsafe on here....
Mikey
  #21 (permalink)
Old 02-02-2008, 08:07 PM
Mikey
But you would install carpet in the wrong house,lol
Congrats on becoming a Mod. Has your taco fixin friend cave you a celabratory taco yet?
I was thinking for some reason that that was the rear brakes.....I need to go MTN Bikein'
Shane
  #22 (permalink)
Old 02-02-2008, 08:57 PM
Wiki Edits: 161
That was in '80 or 81..
You know we're wrecking Dewey's thread...
I'll get with the program..
I think a guy could use a big gate hinge, like for a swinging garage door, and do away with the wood altogether..
Only if he couldn't work with wood....
Mikey
  #23 (permalink)
Old 02-02-2008, 09:31 PM
Mikey
Yeah we are, Sorry Dewey . you could use a regular garage door hinge too.
Shane
  #24 (permalink)
Old 02-28-2008, 11:33 AM
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Or maybe do away with the hinge, mount a V-block on a roller skate, mount a guide on the work table, plop your die grinder/cutoff in the V, and roll it along the guide to cut the chosen victim. Don't have to U-bolt the grinder then.
Kind of an upside-down radial arm saw without the arm.
Might need a better fit than a V-block for some die grinders.
[edited to add:]
No roller skate? Put guides on the bottom of the V-block and slide it along the guide on the work table.
Hmm. 2 small V-pulleys in an in-line skate formation, running on top of a piece of electrical conduit would give a repeatable straight-line path. Natural tendency would be to bear down on it while pushing the cutter past the work, keeping the die grinder deep in the V-block and the pulleys tight on the conduit -- any wear is automatically taken up on. Should be able to cut in a straight line for any reasonable length of conduit.
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 03:41 PM
To Chop or not to Chop 1931 steve Body - Exterior 23 03-20-2008 11:23 AM
How do you chop a Fiberglass Body? FordMan1951 Body - Exterior 8 02-13-2007 09:08 AM
mini spray gun porter cable quack Body - Exterior 5 04-19-2006 09:47 AM
