hood - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2017, 11:31 AM
Last journal entry: door trim
hood
I'm trying to figure out a way to hold down the hood panels on my streetrod. I am only using the two top panels on my 31 chevy coupe and need a way to hold the sides down they pivot up from the center rod. I don't want those ugly *** big leather straps or the funny looking springs that attach to the frame. I was thinking of chrome tension springs one in each corner of the hood sides. anybody ever try to do this? thanks
Old 02-03-2017, 04:25 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I am thinking some small bear claw latches as they can be hidden under the hood. Just use a cable between the latches so you pull the cable which unlocks the latches and lift the hood. In your case you will need four latches. I get mine from watsons street works. They are in NH.
Sam
Part number L24E for a pair of them.
The Following User Says Thank You to OneMoreTime For This Useful Post:
22george (02-09-2017)
Old 02-09-2017, 07:17 AM
i do drive on highways and sometimes fast, why else own a streetrod. for now i decided to use some small bolts 10/24 fastened through the hood corners into the grill with lock nut and sheet metal into the cowl. I figure ill try this only takes a couple of minutes to take out and if i don't like it i only have 4 little holes to fill later.
Small gap between hood scoop and hood Lizer Body - Exterior 21 04-17-2013 09:32 AM
Replacing a metal hood with a fiberglass hood dasyhard Body - Exterior 9 07-12-2011 10:18 PM
Hood pins verse stock hood latch 62440 Body - Exterior 3 08-23-2010 09:30 AM
Fiberglassing a hood scoop on a metal hood Quarter Flash Body - Exterior 11 09-25-2007 06:22 PM
Poll: Showing cars - Hood up or hood down? loyter Hotrodders' Lounge 23 06-24-2007 06:21 AM
