hood hinges - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 08-29-2019, 12:13 AM
fiftyv8's Avatar
Well folks, I got my laser cut hinge components back today.
I have started assembling them, but first had to drill pivot holes out to size and tap a couple of threads to attach the coupling plates that coordinate the front and rear arms as they lift together.
I've spent many a hour on my sheet metal but a pic will not show where all my time has gone.
In saying that I have been bending and shaping these panels to tweak them in to a nicer fit and alignment.
Time, that I could never afford to pay somebody else to spend for me...
The Following User Says Thank You to fiftyv8 For This Useful Post:
123pugsy (08-29-2019)
  #77 (permalink)
Old 09-03-2019, 12:07 AM
fiftyv8's Avatar
Both hinges assembled and all is good.
Just getting ready to progress to attaching them to the firewall and work out how the hood underside will attach to my hinges.
Would have been a much easier job if there was no engine in place.
Something I will need to remember for any future projects.
I have also finalised the install and mounting of the body side hood latching...
ID:	447377   Click image for larger version
ID:	447379   Click image for larger version
The Following 2 Users Say Thank You to fiftyv8 For This Useful Post:
123pugsy (09-03-2019), MARTINSR (09-03-2019)
  #78 (permalink)
Old 09-05-2019, 06:10 PM
fiftyv8's Avatar
Hinges mounted and seem to have worked out OK for now.
I used insert nuts.
A added a small arm to my latch for easy operation.
ID:	447437   Click image for larger version
ID:	447439   Click image for larger version
123pugsy (09-06-2019), MARTINSR (09-06-2019)
  #79 (permalink)
Old 09-07-2019, 06:27 PM
fiftyv8's Avatar
It is always good for the ego to share progress and success during a build as I have been doing during this hood project.
However, just when all the components are about to come together for the first time, I have just discovered that even with all my good intentions, that the hinges are letting me down.
In other words I have hit a speed bump in my progress.
I guess this has come about by trying to use a hinge design that was not actually made specifically for my project.
The issue which has come to light, but has been in the back of our minds is the need to achieve enough lift at the tail end or firewall end of the hood as it rises, so it does not bind or drag on the body during its movement.
Today, I did a mock up fit to track the movement of the hood as if it was being opened.
Unfortunately, the tail is binding as it rises out of the closed position and it will not work as planned.
It seems at first look, that I need to speed up the rear lift as well and gain a little more height.
I have trialled several improvements and arm positions and lengths to see if I can improve this situation.
During the initial CAD design work, we did improve the lift from 9mm to almost 15mm which obviously helped.
Tomorrow, I will visit the laser guy and see if we can impose some of my solution ideas into his CAD system and keep moving forward.
I am hoping to beat this issue, but do expect to have to lose something in the process, most likely it will be front lift height from what I can tell...
It is not only a question of lift, but a related rate of forward movement during the lift.
I am still trying to avoid tossing it all into the trash can, fingers crossed...
  #80 (permalink)
Old 09-07-2019, 08:38 PM
Have you considered changing the angle where the hood and cowl meet. By raking the cowl angle back the requirements for the lift at the rear would change. It might be that you could do that and make it look like a custom touch and not a "work around solution."
You might also trim the corner of the hood and add a rolled out portion on the cowl to maintain the hood gap.
John
The Following User Says Thank You to John long For This Useful Post:
fiftyv8 (09-08-2019)
  #81 (permalink)
Old 09-07-2019, 10:00 PM
I'm not sure what you mean John by "racking the cowl angle back." I would say rotate the hinge forward at the top, this would raise the rear of the hood. You may be saying this and my brain just isn't working well.
That would go without saying with this move by the way, it is NOT working well.
The Following User Says Thank You to MARTINSR For This Useful Post:
  #82 (permalink)
Old 09-07-2019, 11:32 PM
fiftyv8's Avatar
These hinges are a tricky concepts to get your head around, especially if they are something that you don't play with often.
I have come up with a couple of refinements that should inch me closer to a solution.
First has been to shorten my base bracket towards the firewall by 6mm, which still gives me some small clearance.
The second thought is to increase the length of the fish plate that can be seen in my last post of pic's.
The fish plate is the small horizontal plate about half way up the hinge with a small machine screw at each end.
We will try that with the laser guy on his CAD and see if the movement is improved.
  #83 (permalink)
Old 09-08-2019, 11:00 AM
But you could rotate the hinge and do the same thing. At the very least find out how much you need to modify it by simply moving it.
  #84 (permalink)
Old 09-08-2019, 05:29 PM
fiftyv8's Avatar
Yes Brian, I have spent sitting and looking at the hinge when mounted and tried various modified arms to see how they influence the movement.
The number of times I have removed the unit from the firewall and then reattached I have lost count of.
Since my hinge design is already in the laser guys CAD system just going back and sitting with him and offering my feedback should help us both determine what will work best.
From the little that I know, the CAD system can show the radius movement with dotted lines of all the arms and by simple length adjustments of arms and pivot centers we should be able to determine what works best.
I am sure it will be some kind of trade off.
I have now implemented my first thought above and shortened the base bracket back 6mm towards the firewall which in my view will reduce the length of the tail which is binding as it lifts.
The shorter tail should go some way to making other adjustments possible and give us a little room to move.
I feel that I am close to a solution but need more skilled help.
  #85 (permalink)
Old 09-08-2019, 10:34 PM
fiftyv8's Avatar
I've visited the laser guy today and we had a play with the hinge and a sit down chat about how to improve my current situation.
He seems to think that my 2 ideas are workable and that the 6mm shortening will definitely help.
We have settled on looking at doubling the length of the fish plate, which seems at first look to satisfy the rear/tail end lift/clearance issues.
I left him looking for a solution to clawing back a lot of my front hood tilt which appears to have been lost with the other 2 improvements.
The hood tilt was at about 43 degrees and we are now down to about 20 degrees which is pretty bad.
I am hoping for 30 degrees or better, so fingers crossed again...
  #86 (permalink)
Old 09-23-2019, 07:44 AM
fiftyv8's Avatar
Sorry folks, I've been off the air here as I am still waiting for my laser guy and I have also updated to a newer computer.
Both results of actions are out of my control and I have spend a good number of hours trying to get my files etc into some sort of order.
I expect to get my laser cut parts by weeks end if the Gods are with me...
Boy that would be a first. hahhaha!!!
MARTINSR (09-23-2019), Rip VW (09-23-2019)
  #87 (permalink)
Old 10-25-2019, 01:52 AM
fiftyv8's Avatar
Finally got my hinges back and need to drill and assemble them.
It is looking to be not that simple as now as I refine them I am discovering other small adjustments that I feel would be advisable to deal with at this point.
The refinements basically will consist of grinding and filing on the bench to ensure full movement and clearance is achieved.
Part of my current problem is that I have lost nearly 50% of my hood lift angle and I need to claw some of that back by doing these refinements.
More pic's soon.
123pugsy (10-25-2019)
  #88 (permalink)
Old 10-25-2019, 02:47 PM
My 32 Plymouth has a custom one piece hood. Right now it lifts off only. I would like to hinge the hood to make showing easier. It takes two people to lift the hood off now. Not very practical. Pictures attached.
Any suggestions how to hinge this hood??
ID:	449011   Click image for larger version
ID:	449013   Click image for larger version
  #89 (permalink)
Old 10-25-2019, 03:16 PM
fiftyv8's Avatar
I am probably not really the guy to ask right now since my hood has not been completed and is not a proven success yet.
However, when I started evaluating a hood and how it would be hinged, my first preference at that time was to have a simple removable hood probably as you started off with.
I quickly came to the realisation that a hood needed to be hinged.
My first idea was to hinge it on one side and have it lift up from the other side and if lucky I could possibly get that idea working so I could lift it from either side and easily remove it completely if required.
I still think that method is best.
In my case I could not get my head around that idea so late into my build as it was likely to interfere with other finished stuff.
Had I given this style of hood much earlier consideration I would have used that method.
So, when considering my other options, I came to the conclusion that hinging from either the grille end or the firewall end were my last real options.
I saw several really good setups hinged from the grille end and much preferred them to the firewall option, but again as my build is basically completed and I would find it difficult to build in extra hinge supports etc, so I found myself painted into a corner with either settling for a removable hood as you have now or a hinged from the firewall.
Once I had worked that all out, it was a matter of finding a suitable hinge method that I thought I liked and would work and do the job.
What I did discover was that hinges ain't hinges and there are just so many versions and variations that trying to work out which one would work best for my set of circumstances was going to be tricky.
Firstly, taking a hinge from another car can/could work but it seemed that it always meant accepting things like size and looks that may not suit the small engine bay of a hot rod..
As you know from reading my thread, that my hood project in the early part was dominated by getting a hinge worked out.
I saw some common and easy to acquire used hinges and also some more specific hot rod hinges while surfing eBay and the like, which helped me home in on a style that I thought could work.
When I saw what reproduction and fancy hot rod products were going to cost, I decided to choice a hinge principle that would work and then scale it down to suit my needs. So custom make my own and so that is what I have attempted to do.
Hinges can be a difficult things to get your head around in the first instance, since they are something we just take for granted and have very little to do with mostly.
Given my time over or on a similar build next time I would definitely take steps to incorporate hinging of a hood much earlier, even if I chose later not to use a hood.
My first choice remains the double side lift hood that is most practical IMHO and is easily removed.
If you think that you could make that hood hinge with your car at the stage it is now, without to much grief and/or doing damage to your car that would be my recommendation.
Feel free to ask more questions should you feel the need.
Something that has sat in the back of my mind since building my hood and hinges that I remain curious as to how early 1960's Falcon and Ranchero hood hinges may have worked for me and avoided the route I have taken.
They are quite slender in size and shape, light and easily modified from what I recall of them in the past.
I am talking about the ones with no springs on them...
  #90 (permalink)
Old 10-26-2019, 05:31 PM
fiftyv8's Avatar
Well, I am back on track again now, my latest hinge appears to be about right and seems to capable of working as required now.
It sure has been a long time coming but worth the wait.
Next step now that I have both hinges temporarily attached to the firewall and level etc, I now need to work out how I will attach them to the inner skin of my hood.
Tomorrow I plan to start cutting out some small pieces of metal to create the attaching faces and see where it leads me.
All that tinkering and filing etc has paid off and the hinges have a nice firm but smooth movement to them which is a great outcome.
Hood hinges? Stovebolter Body - Exterior 9 03-23-2008 03:30 PM
Hood Hinges ChrisMiddleron Body - Exterior 3 09-26-2003 10:47 PM
HOOD HINGES bomo Body - Exterior 2 12-26-2002 07:57 AM
hood hinges? John Boy Body - Exterior 4 10-11-2002 04:18 AM
57 p.u. hood hinges slider in wa Body - Exterior 5 10-10-2002 03:51 PM
